Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-09-2011, 02:23 PM   #1
72shortbed12
1997 Jimmy engine questions
Just picked up a really clean 97 jimmy for $600! It threw a rod through the pan and block so they took an older block and did a full rebuild and bolted everything on minus the oil pan and timing cover. The motor looks great and the paperwork shows a reputable machinist did the work so I'm not worried about it. It has the right crankshaft in it but I've read about issues with the oil pan and timing cover. I know they changed in 96 so will the aluminum pan and plastic timing cover work on the older block? If not what is the best way to go about finishing it? The casting # is 471594 but the number on the pad in front of the passenger side head is wore out to much to be read. It does have a block off plate where the manual fuel pump used to mount. Anyway ideas on the year of the block? Are there any other issues I might run into?
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
