Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-12-2011, 10:11 PM   #1
bmnk
bmnk's Avatar
Speakers / Amp / Confused?
Ok, So I'm about to wire up my 52' truck. I have:
"Secret Audio" from Custom Autosound
A small amp
Set of 3" speakers for the center of the dash
Set of 4" Polk Speakers with 45w RMS - 4ohms
Set of Alpine 5x7s with 75w RMS -4ohms.
The Amp power output is 50w RMS x 2 @ 4ohms
75w RMS x 2 @ 2ohms
150w RMS x 1 @ 4ohms
My plan is to hook the small 3" speakers to the deck -- Then hook the 4" and 5x7s up to the Amp in parallel.
If I'm thinking correctly the speakers hooked up to the amp will then run at 2ohms, and will be powered at 37.5w RMS.
My question is 1) am I right, or completely wrong?-- 2) would I be further ahead to only power the Alpine 5x7's with the amp?
Any help advice would be great.....
bmnk is offline   Reply With Quote
Old 05-13-2011, 12:36 AM   #2
thelowone
thelowone's Avatar
Re: Speakers / Amp / Confused?
I would just run the 5x7s off the amp for the best sound, or go with a 4 channel amp if you want to run both sets of speakers.
1994 GMC Sonoma, Bagged, Shaved, Custom paint "Lonoma"
1992 Chevy 1500 2wd "old blue"
1995 Saturn SL1 D.D.
thelowone is offline   Reply With Quote
Old 05-13-2011, 10:43 AM   #3
Gobbles
Gobbles's Avatar
X2 I would just get more channels!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 05-13-2011, 11:27 AM   #4
jimmydean
jimmydean's Avatar
It would work that way, but your 5x7 might be underpowered. I would either get a bigger 4 channel, or another small amp.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-15-2011, 10:58 PM   #5
bmnk
bmnk's Avatar
Well I ended up taking everyone advice and running the 5x7"s to the amp, and running the two smaller set of speakers off the main deck.
It sounds great.
