Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-13-2011, 02:20 PM   #1
Mikec10
Mikec10's Avatar
Dash brake light stays on?
So.. this morning i had a little accident with my garage door.. Truck was left in gear, forgot about it, turned key, truck fired up and smashed into the garage door DOH, no damage to the truck, big dent in the garage door lol, dads gonna kill me. Anyway after this happened, my brake light stays on, the one on the dash under the fuel gauge. Truck is a 1980, not sure why that parking brake light would stay on considering my parking brake pedal is seized and doesn't work (hence why the truck stays in gear) any ideas as to why it stays on?
more info:
Manual brakes
No abs
disk front drums back
brakes dont feel any different
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 05-13-2011, 10:36 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Dash brake light stays on?
I'd actually like to know to....my brake light stays on all the time too........I checked everything....to pass inspection I just had to unplug the light socket....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 05-14-2011, 08:06 AM   #3
cdowns
cdowns's Avatar
i doubt that light is for a parking brake but for brake failure warning// have you checked your brake fluid? i'd look for the pin on the propertioning valve and try to reset it
Old 05-14-2011, 01:15 PM   #4
Mikec10
Mikec10's Avatar
i have a full resiover of fluid, i dont really know much about brakes, where is the proportioning valve?
Old 05-14-2011, 02:43 PM   #5
cdowns
cdowns's Avatar
coming from the master cyl there are 2short brake lines the go to the proportioning valve, a sort of rectangular shaped thing// there will b one wire conncted to a switch that senses the brake system failure mode// there is also a pin normally toward the front of the valve,it is sometimes covered up by a rubber bubble thingy//you take a clamp lenthwise and try to push the pin into the centering position to turn the light out
Old 05-14-2011, 03:41 PM   #6
Mikec10
Mikec10's Avatar
Okay yeah i found the valve and i did find something coverd by a rubber bubble.
can i take the rubber bubble off? or should i just try to push it in
Old 05-15-2011, 06:18 PM   #7
379redneck
379redneck's Avatar
Mine did the same thing the other day after I slammed on the brakes. The light wouldnt go off and then I was driving behind somebody who slammed their brakes, and when I slammed mine is when the light went out.
I didnt know the light was for the entire brake system, I thought it was just the parking brake. Good thing to know.
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 05-15-2011, 07:55 PM   #8
Mikec10
Mikec10's Avatar
Thats exactly why mine turned on i think, i slammed on my brakes to stop from smashing into my garage lol.
Old 05-19-2011, 05:13 PM   #9
379redneck
379redneck's Avatar
Try pushing the brake pedal hard when you are not moving. I would also go over the entire system to make sure nothing is bad. Mine has come on two more times and it shuts off when I press the brakes hard, but my brakes have also become progessively more spungy since I bought my truck so there might actualy be a problem making the light come on.
Old 05-19-2011, 10:44 PM   #10
fishingjred73
fishingjred73's Avatar
cdowns hit the nail on the head!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
brake, brake light, dash light
