Old 05-17-2011, 06:36 AM   #1
1984 t type
700r4 vs. 4l60e
What type of difference in gas mileage would I see if I used a 700r4 instead of a 4l60e on a 5.3 swap ? The reason I am considering going with the 700 is because I just had the trans rebuilt.
1987 Buick Grand National
2018 Road Glide Special
1984 t type is offline   Reply With Quote
Old 05-17-2011, 09:54 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 700r4 vs. 4l60e
Biggest difference you would see is probably from the way the trannies are geared. I imagine you'd see a slight drop using the 700, plus you'd be going to imo an inferior trans.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-17-2011, 11:16 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 700r4 vs. 4l60e
I assume it is int he burb? mileage really wouldnt be a factor would it?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-17-2011, 11:37 AM   #4
1984 t type
Re: 700r4 vs. 4l60e
It is for my burb. Want to get away from the carb 350 and pick up some mpg's. Just wondering if the price of a rebuilt 4l60e was worth it. My 700 is freshly rebuilt so if it won't hurt performance or mpg's to bad I will use it till it craps out.
Old 05-17-2011, 12:33 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 700r4 vs. 4l60e
its a 700r4, you shouldn't have to wait too long.
Old 05-17-2011, 03:43 PM   #6
SactoJim
SactoJim's Avatar
Re: 700r4 vs. 4l60e
Pretty much the same transmissions from what (little) I know! I believe they are geared the same as well. I think GM just renamed the 700r4 to the 4l60 and 4l60E which has to be controlled electronically. I don't think you would see any difference and would be better off with the 4l60E because it's controlled by the 5.3 ECU.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 05-17-2011, 03:57 PM   #7
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: 700r4 vs. 4l60e
Nailed it! They are they use the same internals. The only difference is in the valve body. One is hyrdaulic (700r4) and one is electronically (4l60e) controlled.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 05-17-2011, 04:03 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 700r4 vs. 4l60e
are you sure they didn't change year to year? My 700r4 had WAY different gearing than the 4l60e I had after it (not in my 66)
Old 05-18-2011, 09:44 AM   #9
clinebarger
Re: 700r4 vs. 4l60e
The 700R4, 4L60, & 4L60E have the same ratios.
1st 3.06
2nd 1.63
3rd 1.00
4th .70
There would be no difference in mileage.
clinebarger is offline   Reply With Quote
