Old 05-17-2011, 08:32 PM   #1
eightyfive
eightyfive's Avatar
454 transmission
Hey guys, im going to be buying a '78 Camaro this weekend which used to have a inline-6 in it (nothing now) and im pretty sure a 454 which i am planning on installing will not bolt up to the original transmission in it now.
What kind of tranny will work?
parts truck- 1982 suburban GMC Sierra Classic
first project- 1985 GMC Sierra Classic
first truck- 1988 GMC Sierra sle
"New" Hot rod 1999 Chevy silverado 5.3L
Workin my way up the food chain
eightyfive is offline   Reply With Quote
Old 05-17-2011, 09:18 PM   #2
turp mcspray
turp mcspray's Avatar
Re: 454 transmission
As far as the older stuff goes,any chevy trans will bolt to any chevy engine. Weather or not it will hold up to the 454, may be another matter. What is in it now?
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 05-17-2011, 09:43 PM   #3
eightyfive
eightyfive's Avatar
its the same tranny that was bolted up to the inline 6
Old 05-17-2011, 11:34 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Which is?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-18-2011, 12:39 AM   #5
eightyfive
eightyfive's Avatar
i woulda told you if i knew haha
Old 05-18-2011, 02:02 AM   #6
GASoline71
GASoline71's Avatar
It's probably a TH350. My ex-wife's car she had when we first got married was a '77 Camaro with an I-6 and a 3 speed standard.
Either way... they'll both bolt up to a big block. Won't last long... but will bolt up.
Gary
Old 05-18-2011, 05:25 AM   #7
dos0711
dos0711's Avatar
Yeah, my tranny man told me to stick with the th400 as I was going to go a different route...he told me it would shred it...lol
dos0711 is offline   Reply With Quote
Old 05-18-2011, 12:08 PM   #8
eightyfive
eightyfive's Avatar
so the bell housing is big enough? just to make things crystal clear, the 454 SHOULD bolt right to the transmission without changing anything?
Old 05-18-2011, 02:39 PM   #9
GASoline71
GASoline71's Avatar
Yes... the back of a Big Block is the same size as the back of a Small Block and vice versa. How do you think the TH400's are being bolted up to Small Blocks?
Gary
Old 05-18-2011, 03:05 PM   #10
geezer#99
geezer#99's Avatar
Don't forget you'll need a 454 flexplate. 454's are externally balanced and the flex plate is balanced differently from small blocks.
Old 05-18-2011, 03:22 PM   #11
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
good knowlegde
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-18-2011, 08:26 PM   #12
eightyfive
eightyfive's Avatar
thanks alot guys! one more question.. what would be the best transmission to have for a 454, i imagine the motor is puttin out at least 450 horse because its cammed, headers, aftermarket intake manifold and carb.
Old 05-18-2011, 08:36 PM   #13
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
The strongest transmission you can get that will hold up to the 454 with little-to-no problems would be the TH400. If you want an overdrive, then the 4L80E, but that requires a standalone computer to work with that old of a car. Very spendy.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 05-19-2011, 06:00 PM   #14
GASoline71
GASoline71's Avatar
TH400's were designed from the factory to handle the torque and HP that Big Blocks put out.
Gary
Old 05-20-2011, 07:09 PM   #15
eightyfive
eightyfive's Avatar
k perfect. thanks guys
Old 05-23-2011, 04:25 PM   #16
weaintscared
weaintscared's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
weaintscared is offline   Reply With Quote
454, camaro, swap, tranny
