05-24-2011, 01:26 PM | #1 |
Astro steering shaft floor placement
I am in the process of installing a steering column out of an astro van into my 59, but I am having trouble determining where the shaft should go through the floor.
Does anyone have any pictures showing this? Thanks. |
05-25-2011, 03:38 PM | #2 |
Re: Astro steering shaft floor placement
Has anyone else had to cut a hole into the firewall above the original steering shaft hole? I'll try to post a pic in afew days.
Thanks |
05-25-2011, 11:54 PM | #3 |
It just takes the right size hole saw to cut the hole along with getting it in the right place so that the wheel is in a comfortable position for you to drive with. Secondly it needs to clear the engine and exhaust and have a fairly clear path to the steering box with the least possibilities of binding up due to tight bends in U joints.
05-26-2011, 10:03 AM | #4 |
I don't have any pics to share but, I prefer the column to be higher onto the firewall. A lower mounted column looks a little better in the engine bay but, a higher floor mount looks MUCH better in the cab. 99.9% of the time the hood is closed anyway. On my 54 the column is actually just above the foot/angled area. The column comes through at the lower portion of the flat part of the firewall.
Jeff |
05-26-2011, 10:56 AM | #5 |
Here's mine, It's not an Astro column. It's an 88 c1500 coulmn.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
05-27-2011, 09:42 PM | #6 |
Thanks for the replies everyone.
Sgtusmc, that is where I cut the hole out for the column, but I wanted see others ideas before I fully committed to that spot. |
