05-25-2011, 09:43 PM | #1 |
Bagged 1968 Suburban doing some towing
Thought I would post some pics of our 1968 Suburban. We put in Slam SS7 bags front and rear.2.5 drop spindles. In the back we bolted them in place thanks to a great FAQ on how to do it. No notch as I plan on doing alot of towing and I am scared to comprimise the strength. The truck pulled great with the stock 327 and 400 tranny. The 3:73 gear probably had alot to do with it. It rode awesome. The truck even is very good on fuel good even when towing. We have a Ride tech E2 controller to install this week. Look foreward to having controll of the height when cruzing.
On monday We picked up entourageguy's 62 Impala and the week before we got the trailer is not a "airstream" It is a TRAVELUX made in Ontario Canada. I will post pics of the trailer and truck in the next post below.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 05-25-2011 at 10:00 PM. |
05-25-2011, 10:08 PM | #2 |
Re: Bagged 1968 Suburban doing some towing
trailer is a 1978 25' Travelux Princess
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 05-25-2011 at 10:36 PM. |
05-25-2011, 10:12 PM | #3 |
Nice! Great pics!
05-25-2011, 10:18 PM | #4 |
beautiful burb
05-25-2011, 10:43 PM | #5 |
and the controlls yet to go in.........
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-25-2011, 10:56 PM | #6 |
How freakin cool!
05-25-2011, 11:29 PM | #7 |
I love this shot! Beautiful Truck!!!
Eric '68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=403690 |
05-26-2011, 09:46 AM | #8 |
Oooooo..... That turned out nice.
05-26-2011, 12:12 PM | #9 |
Tasty Cakes!
Looks great! On the rear bags did you use mounting plates or just bolt them to the frame/trailing arm?
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
05-26-2011, 08:02 PM | #10 |
I bolted them to the frame right in place of the coil springs.
05-27-2011, 12:22 AM | #11 |
Looks great 72MARIO, were is this FAQ you speak of?
Scott S 54 Chevy Pick-Up 71 Chevy Suburban 76 FJ40 LandCruiser - 454, TH350, NP205, Ford 9" 98 Dodge Ram 2500 4X4 Cummins |
05-27-2011, 12:25 AM | #12 |
Prestige Worldwide
That is one cool burb you got there!!
05-27-2011, 12:51 AM | #13 |
What?
X2! Awesome pic!
Totally dig the Impala, and the Princess trailer! I would love to pull a vintage Air Stream behind my Burb some day, if anything do a cool photo shoot with one.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-27-2011, 01:00 AM | #14 |
Tasty Cakes!
Was it a PITA drilling the holes in the frame w/the body on?
05-28-2011, 11:29 AM | #15 |
Looks sweet Mario. I plan on purchasing an Airstream as soon as I get my Burb back on the road.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-28-2011, 01:37 PM | #16 |
Go to the home page & click 'Forums', then scroll down to: Info center >> FAQ's >> Truck Tech
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-28-2011 at 01:38 PM. |
05-28-2011, 10:00 PM | #17 |
I had a hard time tracking it down again...... link to bag install.
http://67-72chevytrucks.com/vboard/s...d.php?t=129463 I pulled the trailing arms off when I did the work to replace the trailing arm bushings and add the 1.5 block. I set the axel on stands close to the floor. I had the frame up high on axel stands. So there was alot or room to work, I would reccomend wearing good goggles when laying on your back drilling. I was wearing saftey glasses over my perscription glass to protect them but, still ended up at the eye doctor getting steel picked off my eye. I dont think I said amything about the ride yet, This truck rides way better on air than on the drop coil's.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 05-28-2011 at 10:10 PM. |
05-29-2011, 12:36 AM | #18 |
Thanks for finding that link. Soon as I finish the engine compartment, I'm gonna start installing the 'bags.
That link is how I was planning to install, but it always helps to have some reassurance that you are doing it right. If all goes as planned, I should be tackling the fronts by Tuesday. Again, I want to let you know your truck looks awesome. Wish the prior owner wouldn't have shot mine with crappy primer. Old patina paint is where it's at! Posted via Mobile Device Posted via Mobile Device
05-29-2011, 12:51 AM | #19 |
Big thanks for finding that link!
06-02-2011, 02:39 PM | #20 |
That burb is perfect
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins Last edited by black_sheep454; 06-02-2011 at 02:40 PM. |
06-03-2011, 11:32 PM | #21 |
Sweet burb. My wife is from Missassauga. I used to love going up in the summer always a bunch of cool cars and trucks around. She lived in peterborough for two years while in university. Really nice area.
Keep it up dude. Juan Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
06-06-2011, 03:47 PM | #22 |
I love the Airstream. I just bought a camper over the weekend to pull behind my '70. I WANTED an Airstream, but I had to resort to practicality with 3 kids. We needed the slide out for the extra room, and the Airstreams with the slides are BIG bucks.
I am just pumped up to be able to justify taking my Burb to Myrtle Beach in a couple weeks. Hope to post some pics of my Burb yanking the camper when I pick it up tomorrow. Awesome Burb!
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
06-17-2011, 12:03 PM | #23 |
I really like your burb. looks real good!
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
