Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-27-2011, 11:32 AM   #1
jstrong394
jstrong394's Avatar
installing a aftermarket radion in an 84
I have the oem radio in my 84, I'm wanting to put a aftermarket headunit in it. Is this possible? What all do I need to do? Also well new aftermarket speakers fit right in?
jstrong394 is offline   Reply With Quote
Old 05-27-2011, 02:59 PM   #2
jimmydean
jimmydean's Avatar
Re: installing a aftermarket radion in an 84
The best and easiest way to do it is to get an install kit from a local shop, or ebay. On the speakers, you have many options. You can replace stock ones with better aftermarket ones of the same size, or you can hack up the area and put whatever you want in.
Crutchfield is a good place to find what "fits" in your truck, but I usually buy my gear local and just use their site for reference.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-27-2011, 04:34 PM   #3
jstrong394
jstrong394's Avatar
One of my concerns was if the new headunit will fit in the stock hole... Seems like its smaller than the new headunits
Old 05-28-2011, 05:48 PM   #4
jstrong394
jstrong394's Avatar
Crutchfield shows one radio that will "fit" my truck but they sell a dash kit. Will the dash kit allow for any radio to fit with out cutting the panel
Old 05-29-2011, 09:57 AM   #5
jimmydean
jimmydean's Avatar
The dash kit either replaces the panel or becomes part of it. I haven't done anything with a square body, but it looks like the dash kit works with the stock panel. You will likely have to remove or cut something, but the kit will make it easier and look better.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-29-2011, 12:41 PM   #6
Mikec10
Mikec10's Avatar
i put in a single din deck into my 80 c10, and your gonna have to cut. plastic and everything, i also used a dash kit. Your still gonna have to cut, a lot!. You will also have to make custom brackets to hold the back of the radio up, at least i had to.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
