Old 05-29-2011, 10:20 PM   #1
l79m20
84 4x4 blazer
Ive got the opportunity to buy an 84 4x4 blazer with 70k miles on it for $2500. auto power windows....not rusty.....should i have any concerns or is this too good to be true?
l79m20 is offline   Reply With Quote
Old 05-29-2011, 10:39 PM   #2
russgt
russgt's Avatar
Re: 84 4x4 blazer
How is it optioned? have any pics?
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 05-29-2011, 10:48 PM   #3
l79m20
Re: 84 4x4 blazer
its an automatic, 4x4, power windows, locks, ac. No pictures.
Old 05-29-2011, 10:56 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: 84 4x4 blazer
How are you certain it is 70k and not 170k or 270k? None the less, if it is a runner and everything works, 2500 is worth looking at.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 05-29-2011, 11:04 PM   #5
l79m20
Re: 84 4x4 blazer
it lived its life down the road from me and an old man owned it. It didnt roll over 100k and go another 70...im sure of that. This may be a stupid question but were all blazers 73-87 1/2 tons or were there some 3/4 tons.
Old 05-30-2011, 04:16 PM   #6
russgt
russgt's Avatar
Re: 84 4x4 blazer
All 1/2 tons
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 05-31-2011, 08:01 PM   #7
l79m20
Re: 84 4x4 blazer
Here is the blazer. I have read some things about a heavy duty optioned blazers. Any ideas on the specs from these?
Old 05-31-2011, 09:23 PM   #8
russgt
russgt's Avatar
Re: 84 4x4 blazer
HD shocks and springs were options. My 76 has both. What was funny to me is that my blazer has 3 leafs per side up front and 6 per side out back. I parted out a 3/4 ton that had 2 leafs per side in the front and 5 per side in the back. Strange
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 06-01-2011, 07:18 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 84 4x4 blazer
I'd wonder if it was sitting...how long
check all rubber lines and tires for cracks
but for 2500 a running working 4x4
grab it
even more so knowing the other owner,if you trust him
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-01-2011, 09:02 PM   #10
l79m20
Re: 84 4x4 blazer
Hopefully I can pick it up this weekend. Is the stock transfer case the same for all Blazers or are they different? Will it be a 203 or 205?
Old 06-01-2011, 09:22 PM   #11
RandyP
RandyP's Avatar
Re: 84 4x4 blazer
84 would be a 208 wouldn't it? If it's a 700r4 at least, which it should be.
Old 06-01-2011, 09:29 PM   #12
l79m20
Re: 84 4x4 blazer
yeah thats right. Any thoughts on the longevity of the different t-cases?
Old 06-01-2011, 09:31 PM   #13
l79m20
Re: 84 4x4 blazer
and or how well the shift on the fly works
Old 06-05-2011, 10:41 PM   #14
l79m20
Re: 84 4x4 blazer
Got the blazer this morning. Gas tank is leaking bad under he skid plate. Now I have to find a new one. Thusly didnt start it. The interior of this thing is nearly perfect. Dash is perfect..no cracks and only the drivers seat has any tears. Only problem that I found was that the auto windows didnt work on either side. Does it have to be running for this to work? Gave it a really good washing and had to leave it home so I could drive home.
Old 06-07-2011, 05:10 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 84 4x4 blazer
the power windows should work with out it running
key turned back too
auto windows do you mean one push and they open?don't have to hold it?
John
Old 06-07-2011, 08:07 PM   #16
l79m20
Re: 84 4x4 blazer
no i just mean that they are power windows. The battery was completely dead and with jumper cables on they still didnt work. The locks did though. The guy I got it from and his kid said they work the last time it ran.
Old 06-08-2011, 09:26 PM   #17
68Timber
I know the pieces fit
68Timber's Avatar
Re: 84 4x4 blazer
Nice score! Don't sweat the power options until you get a new tank in, get the battery charged and the truck running. A complete and clean interior is a great score, interior parts add up big and quick. Subscribing for updates.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-11-2011, 11:53 PM   #18
l79m20
Re: 84 4x4 blazer
I have had lots of good luck with all LMC parts, but am considering buying the fuel tank from classic parts. They are both in KC which is nice and close to me. Just curious if anyone has had any experiences with them or any other parts companies. LMC tank....$135......Classic Parts tank....$95. Cheaper is better right?
Old 06-12-2011, 12:49 AM   #19
68Timber
68Timber's Avatar
Re: 84 4x4 blazer
So far I haven't been burned by either one of them. Ask some questions and see if they're both constructed the same. I've good luck with both, but my borrowed motto is trust, but verify.
John
74 Honda Z50 build
Old 06-12-2011, 08:39 AM   #20
Re: 84 4x4 blazer
Sounds like you got a similar deal to the one I got with my '85 Jimmy. Sounds like similar options,too. That skid plate caused the rusted tank by holding mud and debris in there which held moisture and corrosives. If you keep the skid plate,make sure you wash out between there all the time.
Old 06-12-2011, 10:02 PM   #21
l79m20
Re: 84 4x4 blazer
I believe it. We found the skid plate and it was very rusty...solid but caked in mud and rusty. Also charged the battery for two days and have come to find out it is bad, but the good news is that after charging for two days it did have enough power to slowly run the drivers window down and up which makes me feel better.
Old 06-13-2011, 10:21 PM   #22
l79m20
Re: 84 4x4 blazer
How do I determine what gears are in the rear end and front end?
Old 06-26-2011, 09:18 PM   #23
l79m20
Re: 84 4x4 blazer
I finally got a weekend back home and got to get busy working on the Blazer. This weekend I stopped by Classic Parts in KC and picked up a 31 gallon fuel tank and a set of straps. They priced matched with LMC on the straps. CP tank was $94 straps were $59. LMC had the tank at $134 and the straps at $29. I wanted to use LMC because I have always had great luck with them but they wouldnt price match and CP would. All in all I am very happy with the quality of parts at CP. Got the tank switched out in a couple hours. Could see daylight through the old one. Gave her a quick shot of ether and she fired right up after over a year and a half of not starting. Changed oil and made sure radiator was full then we pulled the top off and took a nice long ride!!!
Old 06-26-2011, 09:20 PM   #24
l79m20
Re: 84 4x4 blazer
Power windows worked great, a/c blows ice cold, goes down the road at 70 straight as an arrow.
Old 06-26-2011, 10:47 PM   #25
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 84 4x4 blazer
awesome
love seeing them with out the top
John
