Old 05-30-2011, 07:23 PM   #1
Psycho Joe
Can you use a GM10 bolt front axle in the rear for rear steering??
I'm contemplating adding a rear steering hydraulic ram kit to my 81 GMC K1500 shortbed. I have an extra GM10 bolt front axle from a 75 GMC 1/2 ton and was wondering if I could flip the axle and use it in the rear? Has anyone done this? I know there are other rear axles that I could buy that are already set up for rear steering but I'm on a budget and just want to know if that 10 bolt front axle will work in the rear.
Thanks everybody.
Psycho Joe is offline   Reply With Quote
Old 05-30-2011, 10:54 PM   #2
bitchin85
bitchin85's Avatar
Re: Can you use a GM10 bolt front axle in the rear for rear steering??
i dont think it would work since the diff isnt centered...
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-31-2011, 01:25 AM   #3
bikes&bowties
bikes&bowties's Avatar
Yes for slow speed stuff... I know 4ws Rockwell trucks don't have centered diffs
bikes&bowties is offline   Reply With Quote
Old 05-31-2011, 01:51 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
No it won't be that easy. Because if you simply turn it around (LEFT TO RIGHT< RIGHT TO LEFT) then the wheels will be turning backwards like the trucks in reverse when it's actually in drive. Same thing would happen if you were to simply rotate the pumpkin to face forward instead of the way it was designed to, the drive shaft would be turning the pinion in the opposite direction and again you'd be turning the rear wheels backwards while in drive.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-31-2011, 02:00 AM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
That'd be funny to see, front wheels going forward and the rear wheels going back.....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 05-31-2011, 07:10 AM   #6
b454rat
There was a truck at Bloomsburb show that did this. I'm pretty sure it was the front in the rear, still had the offset diff.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 05-31-2011, 10:27 AM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
My brother-n-law had Blazer set up with a front axle in the rear, I dont know what they did to make it work (he bought it that way) it was cool to play with but drove wierd on the street. I'll see if I can find picture's .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 05-31-2011, 10:40 AM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
these picture's dont really show much but here they are. he bought it already set up, so we dont have any detail's bought how they made it work.
'85 1/2 ton CCSB
'92 S10 350/350
Old 05-31-2011, 11:24 AM   #9
Tony@AirRideTech
Junior Member
I just knew that was a reflection of a 60 Chev in the bumper and the last picture confirmed it! ha ha ha ha ha
Tony@AirRideTech is offline   Reply With Quote
Old 05-31-2011, 12:18 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
he has two of them, that was actualy use'd in the movie Jeaper's Creaper's.
'85 1/2 ton CCSB
'92 S10 350/350
Old 05-31-2011, 12:30 PM   #11
Psycho Joe
I get the idea that if you turn it around everything will be backwards, but doesn't the front and rear pinions spin in the same direction (Clockwise)? If so than flipping the pumpkin should work because the clockwise rotation doesn't change.
As far as the offset pumpkin I think that should work too. As long as the driveshaft isn't too angled. I wonder if it's just better to have the steering knuckles and shafts cut to fit onto a 12 bolt rear axle?
Thanks again people.
Old 05-31-2011, 01:56 PM   #12
iluvmy72
every bone in my body screams "THUNK, CRACK, SMASH" when I see something like this. I cannot see myself driving this on the HWY and not wrecking.
iluvmy72 is offline   Reply With Quote
Old 05-31-2011, 01:58 PM   #13
Pyrotechnic
Pyrotechnic's Avatar
On the Quadrasteer trucks, the rear axle was a Dana 60 rear axle with Dana 60 front steering setup.
There's a lot of room under these trucks, I think you could get away with a regular front axle flipped over without spending a ton.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-31-2011, 07:25 PM   #14
LONGHAIR
Yes, it CAN be done. I have personally done three of them....but I don't think I would bother to do it with a 10-bolt.
10 bolts are not so great for larger tires in the first place. I'm would be willing to bet that big tires are going along with this type of project.
The off-set of the differential is a non-issue. The driveshaft can easily compensate for this....
"Centering" the differential brings custom axles into the picture. Not only does this cost $$$ in the first place, if you ever were to break one...the time and money come up again. Another reason to up-grade from the beginning
"Technically" the front differential is being turned the wrong direction from the beginning. It is running on the coast side of the gears to drive the truck foreward. (Sad to have to say) but Ford is the only one to to this correctly from the factory. Those "Hi-pinion" axles are "reverse rotation", so they do run on the right side of the gear teeth.
The main thing to remember is that if you intend to keep the leaf-spring suspension, you have to move them in-ward to allow for tire clearance (so they can turn. If you move the spring mounts under the frame, instead of outside it, you can retain the factory spring mounts on the axle housing.
For safety, I would recommend fabricating a "locking" device to hold the wheels straight. The hydraulics will have a tendency to "drift" on the highway...constantly correcting it gets old on longer trips.
I would also put a keyed switch on the pump. This keeps "accidents" from happening and allows you to let other people drive the truck w/o the fear of them crashing it....or someone else.
It is fun to drive one like that, but it does take a bit of practice to master it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-31-2011, 08:14 PM   #15
76stepsidechevy
I'd immagine there would be some torque steer with axles that different in legth. Ive had to limp a few jeeps home in front wheel drive due to a damaged rear driveshaft or rear end and it was a weird feeling. Maybe it wouldn't be as bad in the rear though.
76stepsidechevy is offline   Reply With Quote
Old 05-31-2011, 09:25 PM   #16
spudz
spudz's Avatar
how about oiling? if you flip the axle upside down, I would fear they wouldn't oil like they should internally.. Maybe not... but I dunno
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 06-01-2011, 07:39 PM   #17
LONGHAIR
You don't flip anything, it just goes in like it was a rear axle.
Torque steer is no more likely than any rear axle. The housing is "solid", so the length of the axles themselves really don't matter.
It happens in front wheel drive applications because the steering wheel is connected to the drive wheels, any traction (or loss of traction) goes directly to the steering wheel.
Old 06-01-2011, 07:48 PM   #18
spudz
spudz's Avatar
ahh I understand now!!!
gm 10 bolt, gmc 1500, sierra classic
