06-03-2011, 09:53 AM | #1 |
Removing oxidation from Aluminum wheels
I recently purchased some slot wheels that are brushed aluminum. There is some oxidation marks on the rims. What can I use to remove this and clean them up? The wheels are not high shine I do not think.
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. |
06-03-2011, 01:47 PM | #2 |
Re: Removing oxidation from Aluminum wheels
Check the FAQ section, just read quite a thread about polishing
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
06-05-2011, 09:03 PM | #3 |
Tot Roddin'
I use to use a product called Blue Magic, but it's no longer available in our area the last time I checked.
Anyone else?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-05-2011, 10:06 PM | #4 |
~Rest In Peace~
r u sure its not clear coat peeling away
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-06-2011, 07:36 AM | #5 |
easiest quickest cheapest way i've always found for a quick painless cleanup of slotted wheels is BRILLO soap pads
do all 4wheels in about 15-20 minutes at a cost of 50cents or so its excellent to use wheels like that or a good first step to a final high polish result
06-06-2011, 06:45 PM | #6 |
The Niner
You could try S100 Polishing Soap available at local Harley dealerships.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
06-18-2011, 11:01 PM | #7 |
Grandpa in the rustmobile...
Cleaning slot wheels:
1st. clean em up. I used oven cleaner and a scotch brite this time. followed with sos pad to get the cleaner off and any left over crud. 2nd. take care of any bumps and scars with agressive sanding. I had to use a file on the lips of a couple. 3rd. start sanding with 600 grit then graduate to 1000, then 1500, then 2000. If you have a set thats not scared up like these you may be able to go strait to 1000. Usually don't have to spend alot of time with each grade, just enound to remove a fine layer of oxidized metal. The 2000 grit will tell the tale. And then your ready to polish. 4th. I used a buffer with fine cut compound and a sprinkle of water, then followed it with "mother's" on a cloth. could use a "powerball" if you have it. That might even work better. that's it. It takes a little time, but I love to take something that looks used up and bring it back.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-01-2012, 12:14 AM | #8 |
i know a guy that polished his slots back in the day when we were parked at the river drinking beer with the river bank sand!
just handfulls of the sand and a cloth... no bull- they looked pretty good |
