Old 06-10-2011, 03:40 PM   #1
ctouchet
ctouchet's Avatar
New Toy
1982 Chevy Blazer 2WD
2012 F150 SuperCrew
2011 GMC 1500 (COMPANY TRUCK)
1982 Chevy Blazer 2WD (Work in Progress)
ctouchet is offline   Reply With Quote
Old 06-10-2011, 04:57 PM   #2
d-666
d-666's Avatar
Re: New Toy
looks like a really good starting point! nice score!
1990 k5 blazer
1990 gmc jimmy
1949 1300 p/u-sold
1977 bbc skylark
96 roadmaster
06 9c1 impala
d-666 is offline   Reply With Quote
Old 06-14-2011, 03:14 PM   #3
ctouchet
ctouchet's Avatar
Re: New Toy
PIcked it up on craigslist for $1300.00 needs carb rebuilt but still runs. Needs some work but its a start. Will post more pics later.
2012 F150 SuperCrew
Old 06-14-2011, 03:33 PM   #4
ctouchet
ctouchet's Avatar
Re: New Toy
Another pic
2012 F150 SuperCrew
Old 06-14-2011, 03:54 PM   #5
ctouchet
ctouchet's Avatar
Re: New Toy
one more
2012 F150 SuperCrew
Old 06-14-2011, 04:02 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: New Toy
looks nice and solid
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-14-2011, 05:06 PM   #7
69C20CUSTOM
69C20CUSTOM's Avatar
Re: New Toy
Looks real nice.
And not a bad deal at $1300
I like the blue and white.
We need top off pics
2003 Nissan Frontier Crewcab 4x4-Daily
1982 Chevy Suburban 3/4ton 4x4, Mud Toy
Lookin for a C10
69C20CUSTOM is offline   Reply With Quote
Old 06-15-2011, 12:44 PM   #8
ctouchet
ctouchet's Avatar
Re: New Toy
what transmission came factory in this?
2012 F150 SuperCrew
Old 06-15-2011, 12:59 PM   #9
68Timber
I know the pieces fit
68Timber's Avatar
Re: New Toy
TH350 or the optional TH700R4.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-15-2011, 01:16 PM   #10
ctouchet
ctouchet's Avatar
Re: New Toy
must be the 700r4 it has overdrive. what is the shape of the pan on a 700R4?
2012 F150 SuperCrew
Old 06-16-2011, 12:03 AM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: New Toy
General Chevrolet Transmission Identification
Transmissions are marked and identified by:
- Casting numbers on the case, extention housing and side cover
(on manual trans).
- Date Casting Codes
- Assembly Date Code Stamping - can be stamped anywhere...
- Chassis Vin Number stamping - beginning in 1962
Chevrolet Automatic Transmission Identification & Description
Automatic transmission types are generally identified by their pan shape.
The THM200 and the THM250 have pans shaped like a THM350, HOWEVER, the THM200 will have the words HYDRAMATIC DIV. and METRIC stamped into the pan.
Chevy Automatic Transmission Description & Usage
THM200 - Light duty, "metric" 3 speed transmission.
THM250 - Used in small 4 cylinder cars (Vega, Sunbird, Monza) from 1973 to 1981 and some Nova/Camaro/Chevelle 6 cylinders in 1974 & 75. The 4 cylinder models have 4 large cooling holes near the torque converter, while on the "bigger cars" there are no cooling holes.
THM200-R4 - Used in GM rear wheel drive cars with the 3.8 V6, 305 & 350 Olds and 301 pontiac from 1981 to 1989. This is a 4 speed, overdrive unit.
THM350 - Medium duty 3 speed trans used from 1969 to 1989, Used in Buick, Olds, Pontiac and Chevrolet cars and Chevy & GMC light trucks until 1987. Generally used in straight and V6 and small block engines. Generally able to handle up to 400 foot pounds of torque.
THM375B - This trans is identical to the THM350, but is considered a heavier duty transmission.
THM375 - This transmission is a derivative of the THM400 sharing the external appearance of the 400. It'll be marked 375-THM on the bottom of the tailshaft housing. It's a light duty version of the THM400, has ABSOLUTELY NO RELATION to the THM375B, and was found in 1972 to 1976 full-size cars. The Turbo 375 was modified to accept the Turbo 350 driveshaft yoke.
THM400 - The THM400 was GM's Heavy-duty 3 speed transmission used from 1964 to 1990. Used on large displacement, high torque engines and engines with towing packages. Generally found in Chevy & GM trucks, cadilacs and large displacement engined, full size GM rear wheel drive cars.
THM700-R4 - 4 Speed transmission used in GM cars and light trucks with the 2.8, 3.1, 4.3, V6, Chevrolet built 305, 350 and 454 engines from 1982 to 1992.
4L60 - Early 1990's saw the 700R4 renamed to the 4L60, and "electronic" models were named 4L60E. 4L60 means 4 forward speeds, L = longitudily mounted (rear wheel drive). 60 is the strength rating (less than the 4L80).
3L80 - The 3L80 is a renamed THM400, used in the early 1990's. The 3L80HD would be the THM475 (heavy duty unit).
4L80 - An overdrive model of the THM400. The 4L80E would be the "electronic" model.
Transmissions with a suffix of "C" on the end of the type (THM200C) indicate the transmission has a lock up torque converter.
Chevy Automatic Transmission Identification: Other Methods
Some transmissions have a code stamped onto them. Others have a tag rivited to the case.
Most transmissions will have a "source serial number" (chassis vin) usually found close to the transmission code. This number will contain division ID #, model year, assembly plant and production sequence (last 6 digits) of the VIN stamped onto the transmission. Example: 19N500001. The source serial number is from the CAR the transmission originally went into, NOT the assembly plant.
Location of source serial number
On the THM350, the VIN will be stamped on either the drivers side housing near the shifter, on the right side of the housing just above the pan, or on a boss behind the bellhousing flange on the passenger side of the transmission.
On the THM400 the VIN is stamped on a machined surface just above the pan on the drivers side.
On the THM200-R4 the VIN is stamped onto the housing towards the rear of the pan, on the drivers side.
On the THM700-R4 the VIN is either stamped onto a boss behind the bellhousing flange on the passenger side, just above the pan on the drivers side, or just behind the governor cover, stamped vertically where the case meets the tailshaft housing.
Prior to 1967, transmission ID numbers contained the plant prefix code, month and date of production (expressed numerically) and a shift code (D = Day, N = Night). From 1967 on, the ID number contained the transmission type or plant prefix, Date (coded below) and a shift code. The constants in decoding the trans ID number are the date the transmission was produced.
Pre-67 Example: C213N - (C = Cleveland Powerglide, February 13, Night Shift)
Post-67 Example: P9E03 - (P = TYPE, 9 = year (1969), E = Month, 03 = Day of Month)
Month code: (NOTICE this is NOT in alphabetic order)
A = Jan, B = Feb, C = Mar, D = Apr, E = May, H = Jun, K = Jul, M = Aug, P = Sep, R = Oct, S = Nov, T = Dec
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 06-16-2011, 11:07 AM   #12
ctouchet
ctouchet's Avatar
Re: New Toy
thanks for information.
2012 F150 SuperCrew
