Old 06-13-2011, 10:54 PM   #1
turbobuick1
turbobuick1's Avatar
'72 C20 rear end for a C10 rear end!
I have a '72 Chevy 3/4 ton C20 truck that I'm basically looking to downgrade to half ton status. My logic behind this is-
1) I'm looking to get the 5 bolt pattern, so I can change my wheels.
2) I'm looking for more of a highway gear (around 3:42 or so). I haven't had time to research or count my gear teeth, but I'm assuming it's a 4:10 or taller.
3) I'm don't need the truck for 3/4 ton duty, and I'm hoping the half ton rear end might be lighter.
4) I'm in the process of a custom engine swap, and will need to make a custom driveshaft. I figure I should put in the rear end I want before I get the driveshaft made.
I should say I have a coil spring rear suspension. I should also say the truck has 72,000 original miles on it, and I just drove this truck from Idaho to Michigan in March, so the rear differential works flawlessly. It is still bolted up in the truck. I will post pictures soon.
And I'm still learning about these trucks, but what axle do I have? It's a Dana isn't it?
turbobuick1 is offline   Reply With Quote
Old 06-13-2011, 11:15 PM   #2
Ackattack
Ackattack's Avatar
Re: Looking to trade my '72 C20 rear end for a C10 rear end!
I swapped my axle and whole front suspension from a donor truck.
I bought the donor truck (72 suburban) for $800 without an engine or working transmission. With the suspension swap, and also getting a decent bench seat out of it, I was able to make all $800 plus some back.
Ackattack is offline   Reply With Quote
Old 06-13-2011, 11:20 PM   #3
turbobuick1
Thanks for the advice, that actually sounds like a good idea. I'll have to keep a look out on Craigslist. I'm already parting one vehicle out though, I'm really not to eager to grab another one!
Old 06-14-2011, 09:35 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: '72 C20 rear end for a C10 rear end!
is the cover on the rear perfectly round, or odd shaped?
Does it have a drop out third member like a ford 9 inch rear?
If yes on both, you have the eaton/corperate rear.
If no to both, then you have the dana.
4.10 and 4.56 were the two gears found in almost all 3/4 ton inline 6 and small block trucks.
Old 06-14-2011, 05:38 PM   #5
turbobuick1
Ah I see. I have what looks like a removable third member like a Ford rear end, so I must have the Eaton/Corporate.
Old 06-14-2011, 07:10 PM   #6
Rumblefish
Did you swap the front to a half ton status? I'm in the same boat man! was it a pretty strait forward swap?
Rumblefish is offline   Reply With Quote
Old 06-14-2011, 10:30 PM   #7
turbobuick1
No I haven't yet. I was hoping it would be as simple as change the rotors, at least to get the 5 lug bolt pattern. I'm hoping the steering knuckles are the same, or at least the spindles are!
Old 06-14-2011, 11:47 PM   #8
Ackattack
Ackattack's Avatar
It is not that simple. The 3/4 ton ball joints (at least the lower ones) are different size.
Old 06-15-2011, 01:43 AM   #9
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
The way I plan to swap out my 3/4 front end for 1/2 ton front is by using ece's conversion spindles, they bolt right in place of the 3/4 ton spindles and come in standard height or drop versions. Here is a link: http://www.earlyclassic.com/catalog....ry=New%20Items
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-15-2011, 10:32 AM   #10
turbobuick1
Thanks for the link, that's a good website and company to know about. I'm guessing that 1/2 ton rotors will not work with 3/4 ton knuckles/spindles? For the front of the truck, all I want is the 5 lug pattern.
Old 06-15-2011, 12:11 PM   #11
Jacfourteen
No it won't work, I wish it were that simple.
Old 06-15-2011, 04:53 PM   #12
mhburdych
looking for nice tailgate, inner fenders, dash pad and sport mirrors
mhburdych is offline   Reply With Quote
Old 06-15-2011, 10:09 PM   #13
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Look in the parts board HERE.
There's always cool stuff cropping up!
Also, check out our Vendor's HERE
These guys know our trucks and are
a wealth of great info and new parts.
Have fun shopping!
ETsC10 is offline   Reply With Quote
