06-16-2011, 07:01 PM | #1 |
Need more help!
Hey, every time i shut the ignition off or turn it on, my heater makes a buzzing noise for about 5 seconds and then is quite. It still works fine, but after a while that sounds gets pretty fricken annoying.
Thanks in advance!
parts truck- 1982 suburban GMC Sierra Classic first project- 1985 GMC Sierra Classic first truck- 1988 GMC Sierra sle "New" Hot rod 1999 Chevy silverado 5.3L ^^^ Workin my way up the food chain |
06-16-2011, 07:05 PM | #2 |
Re: Need more help!
BTW, its a 1988 gmc sierra sle 2wd with a 305.
06-16-2011, 10:34 PM | #3 |
laying low
Re: Need more help!
One of the hvac doors is most likely going back to open or closed position making that noise. My 88 did the same thing. If everything works like it should you don't have a problem.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-18-2011, 02:24 PM | #4 |
Re: Need more help!
yeah everything works, so thats normal for these trucks?
06-18-2011, 05:30 PM | #5 |
Old Skool Club
Re: Need more help!
I think that's what he's saying. If your heat and a/c work okay, and your blower functions in all speeds and you can select heat, air or defrost without any issues...but you have that annoying noise....yeah, it's good.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-18-2011, 07:37 PM | #6 |
laying low
Re: Need more help!
Right. It's normal.
06-19-2011, 07:07 PM | #7 | |
Chevys Kick A$$
Re: Need more help!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
Tags |
buzzing, heater |
