Old 06-18-2011, 03:54 PM   #1
76chevybowtie
76 chevy full size driveline question
hey guys
i just joined and i was wondering if you could help me out.
i have a 1976 chevy 3/4 ton pickup and im gonna lift it. i was just wonderin if i go with a 6 inch kit from skyjacker will i have to get different drivelines?
thanks.
76chevybowtie is offline   Reply With Quote
Old 06-18-2011, 06:15 PM   #2
Toxic Redline
Toxic Redline's Avatar
Re: 76 chevy full size driveline question
well i have a 4 inch lift and my rear driveline is like right on end im getting a new one soon so i say you would have to get new drive lines, 4 inch is about the biggest you can "get by" with but even then its iffy that you might ruin splines on the output shaft,
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 06-18-2011, 10:02 PM   #3
76chevybowtie
What tranny and t case you got?
Old 06-18-2011, 10:32 PM   #4
BigRed76
BigRed76's Avatar
I did a 4" lift on my 1/2 ton and that stretched the driveshafts to the max, I was told previously that a 6" lift would force me to get new driveshafts and I believe it now.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-18-2011, 10:58 PM   #5
76chevybowtie
my truck has a th350 with a 203 t case i believe that makes a difference........ doesnt it?
Old 06-19-2011, 08:43 AM   #6
LONGHAIR
Maybe, but not in a good way. The NP203 is longer than the others, so it makes the driveshaft shorter from the start. A shorter shaft makes for more of an angular change. This makes it more likely that your existing shaft will be too short.
The front is probably going to need work either way.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-19-2011, 10:28 PM   #7
Toxic Redline
No with a four inch the driveline will work, that is if you feel comfortable with a 1/2 in to an inch left on your outputshaft,(usually you have like 3 inches in there) go for it,
but dont start crying when you drop a line on the freeway/offroad and ruin your line and or exhaust/tank/bed/wires, and possibly ruin your tail shaft gears ,,its made to be a certain length, , i'm playing this driveline game right now, ,
all im saying is that
with my 208 tranfercase it worked (still had like almost two inches) but now with this new tranny and 205 it wont, with the 208 you could probably use a burban driveline for a longbed truck, but with my 205 it is on end,
if you do your lift put the driveline in (if it fits) and then push up and down on the line by the transfercase, if it moves excessively and you can hear a (click, click, click) then its too short, get a longer on, , , it will work ..... sorta.... but who knows how long
68 c20 dump bed
chevy, drivelines, driveshafts, llift, suspension
