Old 06-19-2011, 10:21 PM   #1
bitchin85
bitchin85's Avatar
37 inch tires 15 inch rim
..or close? who makes one thats a radial that dont cost ten grand per tire? i dont want to get rid of the rims i have now i love them but with 11 inches of lift, it makes my 35s look too tiny.. i dont mud it too much i dont need anything wicked just an agressive all terrain or close.. thanks guys
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 06-19-2011, 10:26 PM   #2
Redcap
Re: 37 inch tires 15 inch rim
Not a 15" rim.
http://www.100dollarman.com/tires.html
Redcap is offline   Reply With Quote
Old 06-19-2011, 10:29 PM   #3
bitchin85
bitchin85's Avatar
what a tease...
Old 06-20-2011, 12:02 AM   #4
Redcap
It is a lot easier if you'll go to a 16" or 16.5" rim.
Old 06-20-2011, 03:55 PM   #5
dieseltech
I'm running toyo open country mt's 37x14.5x15.......bought mine used but i think there somewhere around the $400-$600 they fit really well in a 15x10 rim
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
Old 06-27-2011, 10:21 PM   #6
bitchin85
bitchin85's Avatar
well i called the local 4x4 shop and there is a few super swampers that i like around 350 each. 37s and 38s i need a radial thats about it i looked at the toyo and liked thembut dont like the 450 each lol there is a nitto also that isnt too bad forget which one though. are the super swampers any good?
Old 06-27-2011, 10:38 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I was going to suggest these toyo open country mt's as well or I think BFGoodrich might make a 37" tire. Swampers are great just aggressive and loud especially on a truck that is a daily driver and driven on the street a lot, plus the tires are going to wear faster.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-27-2011, 10:41 PM   #8
nate_g_2003
nate_g_2003's Avatar
go to 16.5 and run surplus HMMWV tires. They can be had pretty cheap, depending on where you look. I have 16.5 Centerlines, and I considered them, but don't want to lift the Burban anymore or have to cut fenders/wheelwells.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 06-27-2011, 11:08 PM   #9
bitchin85
bitchin85's Avatar
id get bigger rims but i love the alum rims i got now and i like the big tire small rim look. ive heard this about the swampers too about them being loud. im driving the truck from michigan to tennessee in a month and i dont want to be shaken out of the cab or listen to them whyning too bad. a little dont bother me but im not going with a tsl
Old 06-27-2011, 11:21 PM   #10
nate_g_2003
Here is a pic of 16.5s with 37 hummer tires. don't know if it is the big tire/small rim look that you want, but you can see how it looks.
-Nathan-
Old 07-11-2011, 09:51 PM   #11
bitchin85
bitchin85's Avatar
well i got the money for the tires now and i want them like yesterday.. every local shop i call says they have nothing that will fit.. i really like the toyos but i dont like the price... any others/. im having a hard time finding some
Old 07-12-2011, 09:51 PM   #12
Mike C
Mike C's Avatar
15's don't allow you the opportunity to easily upgrade your axles if you decide you want to do that at some point to 8 luggers.
Nates pic is of the 36" bias ply Humvee tires, same as I have on my Jimmy with 16.5 Centerlines. They are exactly the same height as my 35" 12.5 15 BFG's that I had on it. The 37" Humvee radial is truly a 37" tire, so 4" lift is probably not enough without trimming and/or moving front axle forward and centering the rear. BUT... Tread Wright sells a rockin' looking re-tread Humvee tire and they are only $145 each.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-13-2011, 09:26 PM   #13
ghettoluxury
ghettoluxury's Avatar
[QUOTE=Mike C;4787221]15's don't allow you the opportunity to easily upgrade your axles if you decide you want to do that at some point to 8 luggers. [QUOTE]
This is not true I am running 35x13.5x15 in my 1 Ton Crew Cab with a Dana 60 up front.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-13-2011, 11:14 PM   #14
bitchin85
bitchin85's Avatar
well i looked everywhere and gave up i got a set of federal cougaria mt 35 12.5 15s they were cheap (ish) and the guys at my local 4x4 shop said they wear pretty good and are awesome off road. should be getting them mounted up tomorrow if they come in soon enough
Old 07-13-2011, 11:50 PM   #15
dammitmitchell
the pollock
dammitmitchell's Avatar
i had mickey t 38x15.50 4 15's.
if your runnin 15 in rim you probably are running too small of axles to handle anythin past 35's.
i sold my 38's, ditched the axles.. went with 37's and 14bolts (check sig)
ut if your interested i have a extra 38 brand new garage kept that the buyer diddnt ever pick up. moutned on a 15 in 5 hole rim. prolly cut you a helllll of a deal on it...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-13-2011, 11:52 PM   #16
dammitmitchell
the pollock
and i'll also jump in.
my 14 bolt rear will not clear 15in rims unless i have a different cut center. those centers make it a total pain to mount the tires. The front calipers need to be ground down also on any3/4 -1 ton axle to clear a 15 in tire. 16's on anything past a 35 inch tires is preferred and almost mandatory.
Army vet 02-08
Old 07-14-2011, 08:29 AM   #17
b454rat
I've had a crapload of 14ff's, all of them cleared 15" rims. What rear do you have??
I had a set of 40" boggers that road smooth down the road. Lower speeds is where they wander and jump around. And sounded sweet, like an old WWII bomber coming down the road. Man I kick myself for selling them....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 07-14-2011, 08:46 AM   #18
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
There's more to it than just a "15" wheel will or won't clear a 1 ton axle..." Shallow backspacing like what ghettoluxury posted definitely helps, pushing the hoop of the wheel out past the point of interference (drum/caliper). Deeper backspaced wheels are where you start getting into 15s that will not clear a 14ff or D60 brakes. The front can usually be fixed with grinding, but the rear is a lost cause without different backspacing. Also usually only steel 15" wheels have a chance to clear, I can't say that I have ever seen an aluminum 8 lug 15" wheel, the material would be too thick and definitely would not clear.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 07-14-2011, 08:58 AM   #19
b454rat
It's been a while, but the 15s I have have at least 4" b/s. The rear is from a 1 ton van, has the huge breaks, and it's close but they clear. I had a set with 4.25" on a 1 ton rear, still cleared. Only issues I've ever had with 15s is clearing a 3/4 front and a 1 ton, but grinding takes care of that.
15" rims have more tire options not to mention cheaper. If you need more capacity, then might have to go with 16s or bigger. But IMO, bigger doesn't always look better, especially on the 70s/80s trucks.
Old 07-14-2011, 09:17 AM   #20
GCncsuHD
GCncsuHD's Avatar
4.25" is the max you can run on 15s for the 14ff with the old style press on drums, the later model slip ons need like 3" or less backspacing or grind the fins off IIRC.
ΜΟΛΩΝ ΛΑΒΕ
Old 07-14-2011, 07:49 PM   #21
Mike C
Mike C's Avatar
I didn't say it couldn't be done, just not easily. Eaton is one of the 15" 8 lug wheel makers. In my reading about 15" wheels for 8 lug axles, most require that you grind down on the caliper and you have to stick the wheel way out to clear brake drums. Your choice, but that is not an area I would consider weakening and I am not a fan of bearing burner rims.
The 15" 8 lug wheels came about so you could run wheels with the safety bead rather than 16.5. Now that you have a TON of options in 16" and 17" rims, I wouldn't do the 8 lug 15" rim thing.
With that said, I have a '76 Blazer, and '83 3/4 ton Suburban, and a set of pretty decent 35 12.5 15 BFG MT's that I have considered marrying.... but it would be strictly off road.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 07-14-2011, 08:09 PM   #22
GCncsuHD
GCncsuHD's Avatar
This.
ΜΟΛΩΝ ΛΑΒΕ
Old 07-14-2011, 08:13 PM   #23
b454rat
Did you ever price tires/wheels between 15" bigger?? I want a set of 35s for my crew for daily driving and winter tires. 40" swampers won't last long and suck on snowy/icy roads. I went to Summit, did some comparison shopping. Just looking for the cheapest of each,
15" wheel, $45, 35" tire, $206
16" $68 $225
17" $76 $245
That's one tire, one wheel. Add four of each, that's a pretty good difference in price. Didn't even look at 16.5s, they are slowly becoming obsolete.
Old 07-14-2011, 09:21 PM   #24
Mike C
Mike C's Avatar
16.5's are quickly becoming obsolete, no argument. And for me it was price, too. Found complete '86 3/4 ton Sub for $300 with 4.10 gears. Found (5) brand new Goodyear Wrangler RTII for $550 including shipping. Found (5) clearance Chrome Centerline Bullet rims for $145 apiece ($725). I turned the rear drums and added new shoes, put new rotors on the front. So I did a complete 3/4 ton axle swap (albeit with the "wimpy" 9.5" 14) for $1750 with 36" tires, 4.10 gears with a Gov-bomb in the back and a full boat of billet rims. And I have a matching spare tire and wheel.
I wish I had thought out what I was going to do to the truck long term when I did these sort of first mods 20 years ago.
After having broke more 12 bolts than I can count, I should have done this years ago and the job would have been almost free! Especially if it was how I had originally swapped to 4.10 rather than buying gears and paying to get them setup. But hey, without all that experience with exploding 12 bolts I wouldn't have all the diff setup experience I have now.
44 Willys MB
52 M38A1
64 Corvette Coupe
