06-20-2011, 02:20 PM | #1 |
Junior Member
hose from gas filler to tank
I checked Autozone and Oriellys site and don't see they. Anyone know where to get one.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-20-2011, 03:00 PM | #2 |
What?
Re: hose from gas filler to tank
I get mine from an industrial hose supply house locally.
Has to be fuel rated. If you need the I.D. of what the hose should be, I will go out to the garage and check for you.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-20-2011, 03:23 PM | #3 |
I assume you are talking about the auxilliary tank. LMC has them http://www.lmctruck.com/icatalog/cb/full.aspx?Page=123
06-20-2011, 03:32 PM | #4 | |
What?
I suppose you could cut to fit...
06-20-2011, 03:50 PM | #5 |
Junior Member
I might need you to do that. I think mine has the GM part number on it.
06-20-2011, 08:37 PM | #6 |
What?
This is the by far the best hose I have found for the fuel fill pipe.
Over the life of my Suburban, previous hoses would rot a year later. Like I said earlier, I get this hose from an industrial hose supply house. (They specialize in making custom hydraulic hose and fittings). I would check around the industrial section of where you live, and look for a shop that supplies hose to the fork lift and big rig community. Just in case you do not have a shop that can get this stuff for you, I am sure if you called the place I go to and talk to them about sending you a section of this stuff I am sure they would. www.hose-man.com BTW: These guys custom made my front brake lines for me to. They salvage the fitting if they can't get it, and in my case no one sold the fitting by itself. I had them make longer than stock hose, since my burb is lifted and it is the original drum brake D44.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 06-20-2011 at 08:46 PM. Reason: Added pictures |
06-20-2011, 09:32 PM | #7 |
Junior Member
thank you for the infomation, I am goiing to look local first and if necessary give them a try
06-21-2011, 10:37 AM | #8 |
A marine supplier should also have the correct size hose.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
06-21-2011, 10:40 AM | #9 |
yep boat suppliers i've found have the best selection of gasfill hoses in stock at most places
