Old 06-20-2011, 10:18 PM   #1
ole red
In and out - headliner
Wanted to know how you all installed headliner. In the back of Burb first and insert each one working forward? Or from front to back? Or do you all install middle ones last?
Thanks Ole Red
69 stepside, 1/2ton, 4X4, 350/350/205
ole red is offline   Reply With Quote
Old 06-20-2011, 11:01 PM   #2
vectorit
What?
vectorit's Avatar
Re: In and out - headliner
I did the front first, rear second, and then the middle two pieces last.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-21-2011, 10:00 PM   #3
ole red
Did you do that with the original headliner or your newer headliner?
Old 06-22-2011, 09:50 AM   #4
vectorit
What?
vectorit's Avatar
I did it with the new headliner.
As for the original, I can't see doing it any different.
The front panel has to be slid forward into place, and the rear has to be slid rearward into place.
The two middle pieces go straight up in, no sliding into place for the most part.
Basically push up from the middle, and then fit the ends into the channel. Once that is done, screw in the single middle screw and then snap on the plastic trim to hold everything in place.
If you can get someone to help you, I highly recommend it!
The panels are big and floppy, and having and extra set of hands to help is a huge bonus.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 06-24-2011, 08:55 AM   #5
Street Smart
Street Smart's Avatar
hey Vectorit, i see you did it with a new headliner. What did you use for new panels. I have a complete set up but the panels are shot.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 06-24-2011, 09:22 AM   #6
vectorit
What?
vectorit's Avatar
I used FRP panel from Lowe's.
Kind of tough to work with, but it has been the best material I have been able to find that is flexible enough for the corners.
http://67-72chevytrucks.com/vboard/s...d.php?t=410459
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 06-24-2011, 12:49 PM   #7
Street Smart
thanks for the info!
