Old 06-22-2011, 01:34 AM   #1
72gmcshorty
72gmcshorty's Avatar
fuel setup for 2006 motor....
So, my motor looks like this one. It has one feed. I was planning on using a fuel sending unit from an 87 blazer (unit has 4 outlets), and fuel pump from 1990 iroc camaro. Do i need to order anything else?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-22-2011, 03:04 AM   #2
ls1nova71
ls1nova71's Avatar
Re: fuel setup for 2006 motor....
You'll also need a Corvette fuel filter/regulator to use the returnless fuel rail.
ls1nova71 is offline   Reply With Quote
Old 06-22-2011, 11:47 AM   #3
72gmcshorty
does this motor have the regulator built in at the fuel rail?
1992 Gmc 2wd
Old 06-22-2011, 01:33 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
No, If it did then you would have a feed and a return line.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-22-2011, 11:24 PM   #5
72gmcshorty
is there a cheaper (yet just as good) alternative to the corvette filter/regulator?
So this is what i have so far:
1990 Jeep Wrangler gas tank (25 gallon. It is what fits, don't ask) - spectra premium #JP1D
1987 Blazer sending unit - spectra premium #FG12k
1990 camaro iroc fuel pump - ACDelco #EP241
2000 corvette filter/regulator - wix - #33737
Anything i might be missing? I plan on ordering from rockauto unless someone can recommend a cheaper place? (I will be getting this stuff shipped to the border so trying to order everything from one location)
1992 Gmc 2wd
Old 06-22-2011, 11:42 PM   #6
ls1nova71
ls1nova71's Avatar
A Wix filter is a pretty good alternative to the $100+ AC Delco, they're about $45. Any other brand I would stay away from.
Old 06-23-2011, 12:12 AM   #7
72gmcshorty
thanks for that. changed it on my list. My total for all that is $269.65 so far (including shipping).
The wix filter is only $35 at rock.
1992 Gmc 2wd
Old 06-23-2011, 12:41 AM   #8
72gmcshorty
Can someone tell me the difference between the EP381 pump vs the EP241? I am using a 25 gallon tank (if that helps). Better yet, can someone tell me what would be the proper replacement pump for a sending unit from a 1987 blazer with 25 gallon tank?
1992 Gmc 2wd
Old 06-23-2011, 10:07 AM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
difference you are asking about is here.
http://www.ls1tech.com/forums/fuelin...-vs-ep381.html
the LS motors need 58PSI at the rail minimum.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-23-2011, 10:59 AM   #10
usmcchevy
usmcchevy's Avatar
Thats where mine came from, I love Rock Auto Make sure to google a discount code for them, I always find 5% off.
Build thread
LSx Swap FAQ index
Old 06-23-2011, 08:10 PM   #11
72gmcshorty
Thanks for this. Changed my list. I wish incorrect info like this (using pump ep241) was taken off this site.
1992 Gmc 2wd
Old 06-23-2011, 08:21 PM   #12
72gmcshorty
Where do you input the code on their website?
1992 Gmc 2wd
Old 06-23-2011, 08:39 PM   #13
usmcchevy
usmcchevy's Avatar
Paste this code in the "how did you hear about us" line on the bottom of your shopping cart: 58568684072636
Build thread
LSx Swap FAQ index
