Old 06-22-2011, 07:12 PM   #1
rcbildr
rcbildr's Avatar
My 85 Burb
Just thought I would post up some recent pics of my 85 diesel 4x4 burb. A couple months ago I got the tube steps and visor on it. I'm pretty much done with the exterior except for fresh paint. Mechanically all it needs is extended brake lines for the front and I need to replace a solenoid in the winch. Next year I hope to have enough to rebuild the engine. This year we had the tranny rebuilt. For the interior I want to put in a rubber floor mat instead of carpet...like what LMC sells. As it sits right now it's on it's 3rd engine, 3rd trans & t-case, 2nd front end, 2nd rear end, and 2nd steering column. My next project for it will be finishing the roof rack. I want to make some pieces that from front to back on the sides. Sorry the pics are very good all I have for a digital camera is my cell phone.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-26-2011, 03:10 PM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: My 85 Burb
Sweet looking burb I like what you have done looks great! Keep up the good work. What's the deal on going through so many drive train parts though been beating on it or just normal wear and tear?
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-26-2011, 09:16 PM   #3
Davidmichael
Davidmichael's Avatar
Re: My 85 Burb
very nice looking burb
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 06-27-2011, 07:15 PM   #4
rcbildr
rcbildr's Avatar
Re: My 85 Burb
Thanks! A lot of it I think was due to normal wear and tear. I bought it with a bad engine...figured it was parked because of a bad head gasket then the water froze in the block and cracked it. The engine I found as a replacament was from a junkyard. That lasted 4 years. When I had the manual in it the trans shop noticed the bearings were going out in the rear end so when I swapped out the that I did the lift. I converted it back to an auto so my girlfriend could drive it. I swaped out the front end because the ball joints were shot on the original one and it was easier to do the swap than replace the ball joints. When I had it n the tire shop getting the 35's they ran the VIN and told me the mileage on it was around 348,000 miles. Now as things go bad we are going to try and rebuild instead of find a replacement. That way we have a zero point...know what I mean. Thanks!!!!
My Projects:
1978 Camaro Z28
Old 06-27-2011, 11:10 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Re: My 85 Burb
Sweet deal ya that's cool makes sense completely. I have an '86 K5 Blazer that is a 6.2 Diesel and the 700R4 its sitting cause the blocks cracked where the starter bolts up due to stupidity from the guy I bought it from. That's why I was asking about the problems you had from your truck to see if I might have some of the same.
-LATER
Old 06-28-2011, 12:39 AM   #6
rcbildr
rcbildr's Avatar
Re: My 85 Burb
So far the only issue I've had with starter bolts was on my 83 shortbed 4x4 diesel. If I remember right, the bracket on the front of the starter worked it's way loose a little bit and one bolt broke...turns out that was the bolt hole my friend had to helicoil when he had the truck. I got lucky and was able to get the end of the bolt out without any problems.
My Projects:
1978 Camaro Z28
