Old 06-26-2011, 09:08 PM   #1
18436572
18436572's Avatar
LS with stock gauges/tach
I have a 1970 short box with stock gauges. Is anyone running stock gauges/tach with their LS swap?
18436572 is offline   Reply With Quote
Old 06-27-2011, 04:01 AM   #2
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: LS with stock gauges/tach
Yes I am running all stock gauges and tach in my truck. The only one that doesn't work is the stock amp gauge. The speedo is controlled via a Cable-X. The tach outout off the pcm runs into a Dakota Digital Tach box that converts the signal up to a V8 signal for the tach (this can also be done in Hptuners). The temp gauge is connected to the temp sending unit on the engine and the Oil pressure is plumbed into the factory oil pressure port with a number of adapters.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 06-27-2011, 09:51 AM   #3
Shon
i too am running Cable X ($300 shipped from Herron Performance).
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-27-2011, 10:08 PM   #4
CamaroChris
You can avoid all that mess if you are using a 4l60e or a 4l80e you can just find a electric speedo out of a 91 burb. I have 3 if you need one. and hook that up. then you can adjust the speedo through the pcm for gears and tire changes
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 07-07-2011, 12:26 PM   #5
BustedTruck
BustedTruck's Avatar
This sounds interesting. any pics? Is it a difficult swap? I may want a speedo from you.
BustedTruck is offline   Reply With Quote
Old 07-08-2011, 02:39 AM   #6
CamaroChris
It is an easy swap, you just follow the circuts around the printed board and rewire to the same as your old cluster. then hook the vss from the pcm to your speedo I have the pigtail connector for the electric speedo as well so you just hook your factory wires to the new harness where they need to go
I LIKE TRUCKS
Old 07-08-2011, 07:13 PM   #7
ls1nova71
ls1nova71's Avatar
I think there has been some confusion on years here. The OP was asking about a '70, which is not the same as the '73-up cluster, which is the one you can switch out for the electronic Suburban/Blazer speedo. Unless you know of a way to put the '90 speedo into the '67-'72 cluster, in which case I'd like to hear about it. I think it could be done, but won't look factory becaust the later speedo only goes to 85mph, and the '67-'72 goes to 100mph. I'm working on something similar, and will post my results if I can get it to work.
ls1nova71 is offline   Reply With Quote
Old 07-15-2011, 07:11 AM   #8
CamaroChris
I can not believe I missed that, I'm sorry for the confusion. I have been reading so much of this forum that I must have confused myself :S
I LIKE TRUCKS
