06-28-2011, 05:53 PM | #1 |
motor exploder
Core support rust - fixable???
I did a quick search but couldn't find much in regard to fixing rust on a core support, namely the area under the battery, which is where my problem is. I don't want to buy an aftermarket one, because from what I've found and read here, they don't fit well. The pics below are what I'm dealing with. Other than the pics, everything else is solid, its just the area under the battery tray that has issues. Any ideas on fixing this? The threaded bolt holes are still there, but the flat area around them is pretty thin, and the lip around the edges is about gone. I have a welder handy and don't mind taking on this challenge, just wanted to check and see if anyone has done this type of repair before and how it turned out. Thanks in advance for any help and/or advice!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
06-28-2011, 06:06 PM | #2 |
Re: Core support rust - fixable???
I wonder if a good used core support would be a better way to go....Just a thought and a bump...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-28-2011, 06:24 PM | #3 |
member #16
Brothers has a patch for that area.
http://www.brotherstrucks.com/prodin...number=RSP72RH
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-28-2011, 06:31 PM | #4 | |
06-28-2011, 06:37 PM | #5 |
motor exploder
Thanks john & 70cst, that's why this board is the best! I know what I'll be doing this weekend...
06-29-2011, 08:46 AM | #6 |
Its fixable.I did mine before the brothers patch showed up. Pretty easy fix. The patch makes it easier. Good luck. Jim
Sorry, couldn't find pic of it repaired. |
06-29-2011, 08:48 AM | #7 |
Closest I could find, Sorry.
06-29-2011, 10:31 AM | #8 |
motor exploder
eagleuh1 - What did you end up using to patch yours up? Your engine bay looks pretty nice, just from what can see in that little snapshot.
I was just over in Russellville this past sunday visiting the in-laws...
06-29-2011, 12:08 PM | #9 |
I made a piece from some scrap sheetmetal I had of the same thickness as original. I just copied the shape of the original, cut it out and bent it up to match the original piece. Then tacked and spot welded it in place, checked the fit and finished tigging it in. Much better than aftermarket core supports. The rest of support was in excellent shape. Wished I had taken pics of piece as being fabricated. Good luck. Jim
06-29-2011, 12:20 PM | #10 |
Heres a little diagram, hope it helps. Jim
06-29-2011, 07:02 PM | #11 |
Been there. Tried to buy the part from brothers, it was out of stock. Bought a piece of sheet metal from Farm and Fleet bent it up, little bit of welding, picked up some weld nuts from Ace, little bit of paint and just like new
06-29-2011, 07:06 PM | #12 |
good job!
06-29-2011, 07:59 PM | #13 |
motor exploder
That looks really good! I ordered the Brother's patch piece a couple days ago, so hopefully it works out okay. Keep the pics coming guys, I like have some inspiration!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 08-25-2011 at 11:25 AM. |
06-29-2011, 11:36 PM | #14 |
laying low
I'm needing to do the same thing to mine. I actually went to Petit jean with that on top of my list of things to pickup. No one there sold them. Guess I'll be ordering from Brothers too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-29-2011, 11:42 PM | #15 |
motor exploder
I looked for one around here too, and didn't find anything. Seems like good parts for 'our' trucks are kinda rare in these parts... But I do see beat up, rusted up, used up stuff all the time!
06-30-2011, 01:18 PM | #16 |
Its not to hard to make the part. Its hidden so well, you don't even have to do that good a job. LOL. I had a machine shop do the 90 deg bends on mine, but i cut it up and welded it. Wish I had a sheet metal break, but I got a lot of wish I hads. Sure beats replacing the whole core support if yours is in fair shape otherwise. Good luck. Jim.
06-30-2011, 01:55 PM | #17 |
Thanks for the comments.
Another problem i had was brothers will list it as back ordered and not actually have ordered them so you could be waiting longer than having a sheet metal shop bend you up some 16ga and just hammer fitting it the rest of the way. |
08-25-2011, 02:06 AM | #18 |
motor exploder
Finally got around to finishing up what I started. I didn't take any pics of what I cut out, but you get the idea from the pics. I just drilled some holes in the patch piece and plug welded it and dressed it with a 60 grit flap disc. Along the bottom, already had holes from drilling out the spot welds, so I plug welded the patch piece using those holes. I tried to stitch weld it on the bottom too, but I shouldn't have, since it looks like crap. Good thing no one will see my pigeon poop welding down there! Btw, this is the first time I've ever done any welding on sheetmetal. I quickly figured out I don't have the patience for it.... I will say the Brother's patch didn't need much trimming, since the rotten spot I had was pretty big. It was a pretty simple fix overall.
08-25-2011, 10:31 PM | #19 |
Good job on the repair. Looks real nice. What did the Brothers patch set you back? Jim
08-25-2011, 11:20 PM | #20 |
motor exploder
If I'm not mistaken, it was right at $50, which is high when you consider its really only about $5 worth of metal, but it had the nuts welded in already, and fit well. It took me a little over an hour to do, including cutting out the rotten spot.
08-26-2011, 10:03 PM | #21 |
Scrapper 1
THAT DAM BATTERY BOX And acid it has tore up more trucks then anything.I bought this truck for 650.00 5 years ago and its pretty straight.Its fully loaded just found all the factory AC brackets and got them mocked up.I was looking into buying a new core support then one just drop out of the sky with a wheel well and battery box for a AC truck and same year YAA here are the pic's
08-26-2011, 10:07 PM | #22 |
Scrapper 1
newer core support for 50.00 with battery tray and wheel well
08-26-2011, 10:08 PM | #23 |
Scrapper 1
Number 3
09-11-2011, 02:13 PM | #24 | |
laying low
And Jim I appreciate your fab skills too. I just don't have the patience for it.
09-11-2011, 07:00 PM | #25 |
laying low
I just ordered a patch panel and radiator cover from Brothers. They have another sale going on until Oct 31. No the patch panel is not one of the sale items....
Tags |
core support, radiator support, rust |
