06-29-2011, 07:50 AM | #1 |
Will a spray-on bedliner de-value my truck?
Ok guys, I've heard arguments for and against spray-on bedliners. I've been thinking about getting my 72 Cheyenne longbed sprayed with some colormatching line-x, when a friend of mine says it will devalue my truck, so now I have doubts. There are a few bumps and dents as well as some surface rust in the bed. Should I try to restore the bed or just line-x it? Here's what I have: Also I just replaced the tailgate don't have new photos yet.
06-29-2011, 08:06 AM | #2 |
KEEP ON TRUCKIN'
Re: Will a spray-on bedliner de-value my truck?
It's your truck, do as you wish. Unless your truck is 100% factory original and looks like it did the day it rolled out of the factory, I would have a liner sprayed in it. Thats just my opinion, others will come and they may vary.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
06-29-2011, 08:14 AM | #3 |
But...if I was buying a truck for show and go the answer is I would not buy a truck with a spray in bed liner. But...if I was buying a DD and work truck than it would make me no differance. As Bishop Trucks said...its your truck. Do what best meets your needs. Good Luck. JMHO
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-29-2011, 11:21 AM | #4 |
the boat guy
I wouldn't do it, unless you were going to keep it and haul firewood with it. Clean it up and hit it with some krylon.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
06-29-2011, 11:38 AM | #5 |
Active Member
I wouldn't do it either. It's a good way to protect the bed but only if you intend to do some dirt, gravel, rock and other type of hauling and never intend to sell it.
I Sprayed Rustoleum on the bottom of my 68 and haul lumber, garden stuff including bricks and it still looks decent. I do use garage floor rubber tiles I bought at Lowes to place under the concrete products. I've seen some ads "for want to buy" trucks that say "no spray on liner on the bed." Also, I talked to a few guys around here that had theirs lined since I was considering doing it on my truck but changed my mind after talking to them. Here's another one. If you do intend to haul I've read where people absolutely oppose a non spray bedliner product but I've had one on one my other trucks and removed it sometime back. I saw none of the rust damage (other than some paint wear off) that has been mentioned by some. I will say that a bedliner is not for everyone though. Too slippery. Last edited by 68gmsee; 06-29-2011 at 12:01 PM. Reason: left out "non spray" |
06-29-2011, 11:52 AM | #6 |
It's your truck, do as you wish. I just don't see a line-x type bedliner hurting the value of the truck. I chose to have mine sprayed because it had light pitting all over the front of the bed floor, and I planned on a liner anyways so instead of having my paint guy smooth out the bed I just had him prep it and spray the liner, it hides alot of minor dents and pitting.
06-29-2011, 12:11 PM | #7 |
I like the look of the color matched bedliner! I use my truck for hauling and would like to go this route, can you give some details on where/how much it cost to get it color matched? Thanks
06-29-2011, 12:24 PM | #8 |
^^^^ that's nice, seen a lot of guys at car shows doing this.
1969 Chevy c20(Miss Hackjob) |
06-29-2011, 12:25 PM | #9 |
So, apparantly I'm not the only one with doubts. The line-x guy quoted $450 then an additional $200 to color match then another $100 to go over the rail, so $750 total. My paint guy quoted around $1500 to clean up and shoot the bed. I'm concerned about spending $750 if my value will drop $1000 (just a guess), so I'm out $1750. But if I go with the paint guy it would add value and I might break even. Still on the rail, so to speak.
06-29-2011, 12:43 PM | #10 |
If I see anice truck that has a spray in liner I automatically suspect a hard life or rotten bed or some combo of both. Neither is appealing to me. I will get famed but in my opinion it is a bandaid to keep from fixing correctly. With that said I just bought a 2006 hd with a spray liner in it- it is garbage, bed was not preped correctly and it is pealing off in sections- looks like crap, but now need to figure out how to get this visual abortion off...
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
06-29-2011, 12:52 PM | #11 | |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
06-29-2011, 01:43 PM | #12 | |
06-29-2011, 01:44 PM | #13 | |
06-29-2011, 01:46 PM | #14 |
I dont know how much a line-x dealer would charge, I had mine done at the paint shop and basically it was a freebie.
06-29-2011, 01:57 PM | #15 |
It seems everyone has their opinion on this. However since my truck is a DD, and its current state is Rat. I would and will go with the spray in liner. I dont plan to go up over the rails though.
There is a good chance my TRUCK will see its share of TRUCK duties, classic or not. And the spray in liner will withstand that. I can understand a numbers matching all original show truck owner would be completely mortified at the thought of a bed liner, but for DD trucks. I dont see why not...... The color matched option above is pretty sweet though. But if i had that much to spend and was putting a "pretty" bed in, i would go with the treated/stained wood flooring i have seen on a few. |
06-29-2011, 02:09 PM | #16 |
I would second the rubber mat you can drop something in it and not damage the bed and then you still have the choice to paint it later if you want to make it a non hauler.
Mine has some dings amd dents on it so I am doing something different I got 4 sheets of heavy gauge brushed S S 9’ X 4’ for free from work and I have a friend at a fab shop with a big shear I am going to do the bed floor, tail gate and bulk head.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
06-29-2011, 02:11 PM | #17 |
~Rest In Peace~
im putting a electric hard tonn. cover on mine i think i just rhino cover the bed since it would be cover and out of site
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
06-29-2011, 03:02 PM | #18 | |
Active Member
Peeling and cracking on a couple, fading on others. One guy hauls mineral blocks (rancher) and noticed a rust bubble had formed under the liner. Probably hairline crack and salt getting under it. It wasn't all one sided, I might add. Some guys liked them. One guy bought a truck with it on and didn't like it because he thought it cheapened the truck. That last one was the one that convinced me not to do it. I'm not knocking anyone for doing it or wanting to do it, it's just not for me on my old trucks. |
06-29-2011, 03:03 PM | #19 |
I am currently doing a spray in liner with my Longhorn and so far I am liking it. It is cost affective and if I do damage the coating I can reapair it myself. Also, as I do the spray in liner the bed is getting new bed wood. The bed wood is pine and has been preped and painted with quality marine/outdoor friendly paint done up in a black moteef. I live in the desert with extreme heat, so I want simple with good elements protection. A pretty bed like you normally see would be nice, but for me and where I live is not a good choice. It comes down to what you like and if you do sell it the new owner can easly remove it with sanding. I wouldn't think it would devalue your truck unless the coating was severly damaged and never touched up before the sale. Good thread, I am glad you asked this question.
R/
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
06-29-2011, 03:51 PM | #20 | |
Vintage 4x4s
06-29-2011, 04:10 PM | #21 |
A bed mat for a 73 and up fits pretty good. Thats what I use
06-29-2011, 05:14 PM | #22 |
If I was buying a truck I would be happier to have one without spray bedliner, so yes it would devalue the truck to me.
I just don't like the stuff...a nice steel bed looks great.
71 GMC 1500 LWB |
06-29-2011, 05:48 PM | #23 |
I had linux sprayed on mine about two years ago. No issues and I love it. Although people consider my truck show quality, I still use it for fun and light hauling. It is a truck afterall. Just two weeks ago we took it on a scuba/camping trip. I am glad I don't have to worry about scuba tanks or other toys scratching my freshly painted truck bed. I also have a pace edwards full metal jacket roll up cover.
Do I care about value? Nope, not planning on selling it ever. Been in the family since new and it is treated like it is part of the family. Last edited by k2rm; 06-29-2011 at 05:49 PM. |
06-29-2011, 06:16 PM | #24 |
~Rest In Peace~
nice color truck ^
06-29-2011, 06:25 PM | #25 |
Thanks Fastwillie. Don't tell my truck, but it is a toyota color.
