Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-30-2011, 12:32 PM   #1
Ynotnow817
Ynotnow817's Avatar
85 S15 fuel gauge bounce
Just bought it and fuel gauge bounces even at stand still. Easy fix?
Thanks in advance
Ynotnow817 is offline   Reply With Quote
Old 06-30-2011, 06:16 PM   #2
tucsonjwt
Re: 85 S15 fuel gauge bounce
Was it an aftermarket "Spectra" brand sending unit? If so, there is no fix, unless you are electronics savvy and can fiddle with resistors (someone else posted a tech link on this, but is was beyond my skill/interest level.)
The aftermarket sending units, unlike AC Delco units, have imprecise resistors and react to every slosh in the fuel tank under motion, when stopping, turning, etc. If the gas gauge eventually settles down, then the sending unit will give you the correct fuel tank level at the end of the bounce cycle. Spectra ($45) bouncing gas gauge vs. AC Delco ($160) no bounce - your choice. I take the bouncing $45 gauge for my work truck.
tucsonjwt is offline   Reply With Quote
Old 07-03-2011, 09:57 AM   #3
Ynotnow817
Ynotnow817's Avatar
Sorry I wasn't clear. I just bought the truck. The gauge is original. I think. The bounce happens even at idle. Any thoughts?
Old 07-07-2011, 02:38 PM   #4
Tink
Tink's Avatar
I have the same problem with my 89... even bounces at idle... from what tucsonjwt wrote, I gather it is the sending unit in the tank - not the gauge. Most likely, it was replaced at some point if the fuel pump was replaced.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 07-09-2011, 06:48 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
usually the problem is in the gauge. the film type resistor on the back between the 2 terminals fails. it is a dampening resistor.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
