07-03-2011, 01:48 AM | #1 |
First attempt at a C10
Recently decided to leave the world of the Mustang and try something 180 degrees the other way. Sold my 2003 Kenne Bell supercharged GT and picked up a '67 C10 SWB. All goes according to plan it will be a long term project that will some day go to one of my two sons. This will be my first attempt at a Chevy so I'm sure along the way I will have countless questions. Please be kind.
William |
07-03-2011, 01:55 AM | #2 |
Re: First attempt at a C10
nice! welcome! sorry to hear about what happened to the rear ps bed side do you have any more pics? wat are your plans? well here we give fast replys and we are all very kind and helpful! glad you traded sides! those mustangs can be a pest :wahh: my sis has a 66 and i do the work...
07-03-2011, 01:58 AM | #3 |
Factory Strippers Rule!
Nice truck you got there, and welcome to the Board! I think you will find everything you need to know on here to get your project done quick. And, since it's a Chevy and not a F***, you can enjoy driving for many trouble-free miles!
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
07-03-2011, 02:04 AM | #4 |
Bought the truck Friday for $2500 for what I see as a pretty decent base... I just see the huge dents as a chance to hone my skills. Plans are for right now get the motor as reliable as possible. I'm hoping to have it as a daily driven project. Hopefully within the week I will be switching from manual brakes to power, adding some lowering springs, converting the 6 lug drums up front to 5 lug disc. Haven't decided on rims and tires as of yet however leaning towards the rally. Assuming the funds haven't been drained I'm looking to add a fuel cell for my safety. Long term goals I'm sure will change over time.
William |
07-03-2011, 02:19 AM | #5 |
you stole it nice truck have fun with it
72 chevrolet 4wd 350/350 swb fleet green mean army machine |
07-03-2011, 10:44 AM | #6 |
PROJECT 7DEUCE
Clean looking truck and welcome to the board.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-03-2011, 02:13 PM | #7 |
welcome & it looks like a soild start..a S/C'd 6.0 with 6 speed will bring back tha memories of tha pony...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
07-03-2011, 05:40 PM | #8 |
First possible setback. When purchased was told the motor was a 283 and after decoding the vin found it wasn't the original motor (originally an online 6). So I'm going over the engine to see what it could be. At the same time I'm looking at a factory hole in the back of the block just to the drivers side of the distributor. Probably close to the same diameter. Decided to run my fingers in it to see if there was any debris. Sure enough there was. From what I could tell there was a small nut in it. When I attempted to get it out it slid into a hole that is located under the intake manifold. Does this hole lead to the crank case and is just a vent? Or does this lead to the valley pan? If it goes to the crank case is my best bet to drop the oil pan? Last thing I want to do is ruin a motor less than two full days in.
William |
07-03-2011, 05:45 PM | #9 |
i would drop the oil pan, but before i do that i would take the intake off.
07-03-2011, 06:24 PM | #10 |
first, i'd pull the dist. and try fishing the nut out with a magnet.
07-03-2011, 07:49 PM | #11 |
PROJECT 7DEUCE
Im confused here its not the dizzy hole correct? Its a hole next to it?
07-03-2011, 07:54 PM | #12 |
It's next to the distributor but on the drivers side. I'll try and post a picture in a bit. I've been online trying to figure out what the hole is and best I can tell is a crank case vent. Then again I could be totally wrong.
William |
07-03-2011, 07:57 PM | #13 |
PROJECT 7DEUCE
Shoot us up a pic of the hole and am pretty confident we can tell ya what it is..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 07-03-2011 at 07:57 PM. Reason: Couldnt spell to save my arse.. |
07-03-2011, 09:12 PM | #14 |
you should be able to see what i'm talking about
William |
07-03-2011, 10:09 PM | #15 |
Decided to name the truck. Debt. Pronounced Deb, the "T" is silent. Unlike my wife.
William |
07-03-2011, 11:27 PM | #16 |
i'm take a shot & say tha hole goes nowhere..
meaning off tha back of tha motor..
07-04-2011, 03:16 AM | #17 |
Needs a Big Block
The seller may not have been lying to ya! that hole is for a road draftt tube found on the earlier v8s including the 283.
Id grab a magnet fish that nut out and then pound a freeze plug into the hole and call it good!!
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
07-04-2011, 10:49 AM | #18 |
Just ordered from ECE a 6" read drop, front 2" drop and the front disc brake kit. And while I wait on the order to be processed and then shipped I can go fishing for that damned nut.
William |
07-04-2011, 10:58 AM | #19 |
Also just ordered the brake booster.
William |
07-13-2011, 12:05 AM | #20 |
All the parts arrived in the mail today minus the 6" read drop springs. Also my brother decided to stop by and we took the intake off and found the nut that dropped in the valley pan.
William |
07-13-2011, 09:27 PM | #21 |
cool beans will.
07-13-2011, 09:47 PM | #22 |
VA72C10
Welcome to the board! Nice truck!
Looking for a 67-72 swb or blazer project in or around VA. |
07-14-2011, 03:52 PM | #23 |
Glad you got the bolt out now get busy! Haha jk
Posted via Mobile Device |
01-01-2012, 04:02 PM | #24 |
After wiring harness issues (wires going to the wrong thing, ie: electronic choke wire going to the horn) and A-arm issues (believe wrong year or model on the drivers side) I put the work on hold for a couple of months. Went back to it yesterday to lower the rear of the truck. Think it turned out nice.
William |
01-01-2012, 04:14 PM | #25 |
Still need to install the track bar and bolt the bed back down.
William |
