Old 07-07-2011, 05:26 PM   #1
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Steering arm
What is the best way to get the steering arm off of the axle? Appreciate any help!!
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 07-07-2011, 07:42 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Steering arm
If it's the one on a Dana 44, alot of penetrant and patience. Under the nuts are cones that are tapered into the arm. I use a flattened cold chisel and tap on the the sides of them. You will have to hammer a little on the arm to shock them loose. when they pop, you may have to tap a screwdriver in the side of the split to lift them off. When beating and banging, dont hit hard enough to damage anything. The one I put in my 69 is from a 85 blazer. It took me a few hours on and off to get it to break free. hope this helps.
Dunenutt is offline   Reply With Quote
Old 07-07-2011, 07:56 PM   #3
LONGHAIR
Re: Steering arm
Nothing wrong with what Dunenutt said, but I find it to be easier to remove the caliper/rotor and the mounting bracket/dust shield. This give far better access to the side of the arm. You can "shock" the tapered cones better by hitting the side of the arm near them, rather than farther out.
Then as Dunenutt said tap a wedge into the side and lift the cones out. They usually "pop" one at a time...and you can hear it when they do.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-07-2011, 08:43 PM   #4
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Steering arm
Good advice above. I used a 4lb sledge for a while, tapping it on the sides of the arm. I removed the caliper and rotor when I did mine as I was replacing the ball joints.
After using the 4lb sledge for a couple of hours, I gave up and brought out the big gun--the 8lb sledge. I think the "trick" is to hit the side of the arm with many repeated hits as opposed to one big hit at a time. Just bang it hard like a machine gun. When I started doing this is when I saw progress. Once you see those little cone washers move up a little, shout a big Hallelujah!!!
Don't give up--it'll come out. Use good ol' PB Blaster, too.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 07-07-2011, 08:50 PM   #5
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Re: Steering arm
Thanks Guy's!! That's what we did. Took a couple of minutes and it was off. Wasn't sure how to get the cones to work them self's out. Thanks again guy's!!
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 07-07-2011, 09:13 PM   #6
TheWhiteElephant
God is good!
Re: Steering arm
HAHA! I could feel your happiness.
There are few feelings in the world that compare to the feeling you get when you FINALLY see those cones move!
Mando
Old 07-08-2011, 12:13 AM   #7
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Re: Steering arm
Oh yeah!! I knew my buddy would know how to get it off. But i had to ask the truck nation. Thanks again!!!
Daren
Rip El Jay
RIP BOBBO'S MOM
