Old 07-07-2011, 08:48 PM   #1
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Dual Exhaust Routed UNDER the Transfer Case
Is anyone running dual exhaust on a '73-'87 4X4 with the passenger-side pipe running UNDER the transfer case and crossmember instead of ABOVE the transfer case? Any pics?
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 07-07-2011, 09:06 PM   #2
Re: Dual Exhaust Routed UNDER the Transfer Case
I always run both pipes over the transfer case cross member. It's real simple. I always run headers and have pipes made that I can bolt on to run the truck to the exhaust shop and they take it from there.
Old 07-07-2011, 09:12 PM   #3
TheWhiteElephant
God is good!
Thanks, Special-K. I got my truck over to the exhaust shop (finally) and took some pictures that Todd (Frankentruck) emailed me a while back so they could route it over the T-case like his. It will work, but it's a tight fit. I asked the exhaust shop to just give me enough room to clear the starter in order to R&I it when necessary. I hope it all goes well.
Anyone else?
Mando
Old 07-07-2011, 09:18 PM   #4
b454rat
No pics, but had plenty of trucks with big blocks, headers, and 2 1/2" pipes go over the t-case.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 07-08-2011, 01:34 AM   #5
USSkoval
Shouldn't be a big deal, my '79 has headers, big block, dual 3inch pipes... it's all tucked up in there.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 07-08-2011, 02:05 AM   #6
MadManAndrew
That's how mine is. Very bad because it'll just get crushed or broke to sh*t if I ever hit anything. I'll be getting it routed above it if I keep it. It's just bad to do it below...I'll still get a picture if you want though.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
