56 - autocross
What are you using for a GAS PEDAL
He hot rod guys. What are you using for a gas pedal (mechanical)? Was thinking about a firewall mount or a floor mount. Not sure which way to go. Pictures, pros, cons, other issues? What have you learned that we can learn from you?
Thanks |
Re: What are you using for a GAS PEDAL
I went with the Lokar floor mount with my 53. Super easy install. I've never had a problem with it. It was kind of expensive, however, I'll most likely buy another for my 59.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
i bought this one off of ebay. type in floor mount gas pedal. it $55. i haven't installed it yet, but i was suprised at the quality for the price.its half the cost of lokar and come with a univeral throttle cable
Some modified piece of junk out of a car that I junked out years ago. Too ugly to take any photos of but it worked for a lot of miles.
In the past I had a bad case of making what I had available at the time work and wasn't too willing to go out and buy aftermarket pieces if I could modify an existing piece. |
Stock inside modified out side!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
56 - autocross
Thanks for the contributions. Doesn't any one else use a gas pedal around here?
I'm using the stock gas pedal and linkage. Works just fine and I like the look of the linkages and stuff.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
this is what I plan to use http://www.speedwaymotors.com/Billet...dals,3411.html
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
I merged a "92" firewall and floor in my 55, so the stock pedal and cable fit in its stock location. That style truck hs a floor mount pedal.
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
57 chevy auto pedal, pivots thru the firewall and uses a rod to the carb. I sold the pedal out of my 74 donor truck to a rodder. It bolts to the fire wall on the inside with a pull cable thru the FW to the carb.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I'm planning on using one something like this once the paint is done
http://www.billetspecialties.com/ite...id=255&pid=956 or this one http://www.cfrperformance.com/CHEVY_.../hz-8854rc.htm |
I'm using the pedal out of the s10 that donated most of the parts for my build. 3 bolts through the toeboard, and uses the stock s10 throttle cable.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#13 |
I am using a pedal from a 95 Astro Van.....bolts to the floor and it will work until I get the urge to get this....http://www.nolimit.net/prodinfo.asp?number=WA8503C
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
#14 |
lokar spoon..........whid
#15 |
Old Heap Driver
WalMart spoon.......I'll get some pictures this weekend, remind me.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
