Old 07-16-2011, 01:04 AM   #1
rayfinseats
add-a-leaf vs. new factory stock front springs
83 chevy half ton 4x4 front. Springs are saggy and flat. What would be the height difference in add-a-leaf vs. new factory stock front springs? I only need 2-4 inches. Street truck.
rayfinseats is offline   Reply With Quote
Old 07-16-2011, 01:35 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: add-a-leaf vs. new factory stock front springs
The front springs on these trucks were near flat to begin with. I'd get a set of 2" lift springs and you should be all right.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-16-2011, 06:30 AM   #3
Add-A-Leafs give about a 2" lift over stock. You need to determine if you springs are sagging or just stock.
Old 07-16-2011, 09:57 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Before I replaced my front springs (with 2.5" Softrides), I installed AALs on my sagging OEM springs. If memory serves, I gained about 1". No idea about brand or specs on the AALs....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 07-17-2011, 01:50 AM   #5
67_SS396
My experience with AAL's is they ride like a chuck wagon. Worse than lift springs and they severely limit flex.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 07-18-2011, 01:06 AM   #6
woodwright
Enjoying left field
woodwright's Avatar
You might check out SD springs. I just bought a new set of stock springs. It was about $270 to my door for the pair.
www.sdtrucksprings.com
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
