Old 07-16-2011, 08:28 PM   #1
jblaven
Smile New Guy here...
Hey guys,
Got an 88 Suburban that was given to us by family back about 7 years ago. We pulled it out of the pasture and did a little work on it back then.
Well, the engine is now up to 283,000. The old 350 is getting tired.
We've decided to revive it and make it live even longer
Starting with ripping out the carpet... Went back with MIP flooring (from LMC) The carpet just doesn't stand a chance against our kids. Also the metal pan under the bench seat was totally rusted inside along the grooves.
I decided to paint them black to match the new floor.
The blue carpet on the side panels were dyed black to match the floor. The upper part of the side panel was hit with the blue vinyl dye. The fiberglass panels around the windows were also repainted with the dye.
Here is the "Dark Blue Met" we would like to paint the Suburban. This pic shows the different "depths" or how dark the blue gets based on the lighting...
Here are shots of the old dash...
And the new one :-)
Repainted the Rear AC housing and vents... I won't tell you how long it took me to tape up the center vents for the chrome paint!
Here is a shot under the hood...
and it's replacement... ...I should say replacement before upgrades
jblaven is offline   Reply With Quote
Old 07-16-2011, 10:03 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: New Guy here...
welcome & nice rig
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-16-2011, 10:37 PM   #3
jblaven
A Little More Horsepower Please
Here is the GM Crate Engine that is the drop in and bolt up replacement for the TBI 350 currently in the '88 Suburban.
Here is the stock cylinder gasket after the cylinder head removal.
Prep for new Vortec cylinder heads :-)
Summit Racing Vortec Heads
Old 07-17-2011, 08:56 AM   #4
jblaven
Engine Fun
These roller rockers are self-aligning and prevent the need for guide plates or machining down the difference of the thickness of said guide plates. They sure are pretty Much more so than the stamped ones.
Giving the hydraulic lifters an oil bath to lift the internal plungers. Otherwise getting a decent initial adjustment on the rocker arms would be tough.
Old 07-17-2011, 09:02 AM   #5
jblaven
Engine Dress Up
GM Performance Vortec Intake Manifold
Old 07-17-2011, 10:19 AM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: New Guy here...
Those rocker arms look great! Too bad they will be covered up. Keep up the good work! Did you use 1.5 or 1.6 rockers?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-17-2011, 10:52 AM   #7
jblaven
Rocker Arms
They are 1.5
I still have the stock cam. I am hoping to pick up a little more torque on the low end of the rpm range with this setup (over the stock cylinder heads and arms).
Old 07-17-2011, 01:06 PM   #8
thirdstreettito
Resident of Here
Re: New Guy here...
Where did you get those plug wire thingys?
~Bradley~
Miss having a truck
Old 07-17-2011, 02:10 PM   #9
Pop's C-10
Pop's C-10's Avatar
Re: New Guy here...
Nice motor, did swap cams or jus lube up tha lifters..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 07-17-2011, 02:18 PM   #10
68Timber
I know the pieces fit
68Timber's Avatar
Re: New Guy here...
Looking good...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-17-2011, 02:55 PM   #11
Boog
laying low
Boog's Avatar
Re: New Guy here...
J that's just too purdy to use. Leave it on the engine stand in a corner of the living room and build something else for the burb.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-17-2011, 03:14 PM   #12
jblaven
Re: New Guy here...
Swapped out the push rods and lifters. Rods are the same length, just a little better than stock.
Old 07-17-2011, 03:14 PM   #13
jblaven
Re: New Guy here...
I know, it makes you pull other things off to paint or replace!
Old 07-17-2011, 03:16 PM   #14
jblaven
Re: New Guy here...
The wire looms were found at Summit Racing. I believe LMC has them in their catalog too.
Old 07-17-2011, 03:37 PM   #15
thirdstreettito
Resident of Here
Re: New Guy here...
No not the looms, the things that look attached to the valve covers.
~Bradley~
Miss having a truck
Old 07-18-2011, 12:49 AM   #16
jblaven
Re: New Guy here...
The rubber grommet thing? It came with the valve covers... It looks like Summit has just the grommet for sale too: Part #SUM-G3410
If you are talking about the chrome valve cover bolts... Trans-Dapt Part #9812
Old 07-18-2011, 01:07 AM   #17
jblaven
ARP Valve Cover Bolts...
I picked up these today, thinking that they might look better than the Trans-Dapt, but they didn't improve the look. ARP makes the better bolt; but for the valve covers, I'll stick with TD.
Old 07-18-2011, 01:08 AM   #18
BLOWN73
Re: New Guy here...
Very cool job
BLOWN73 is offline   Reply With Quote
Old 07-18-2011, 01:22 AM   #19
jblaven
Re: New Guy here...
I could drop it in the Jag... I just don't have the heart to displace a perfectly good V12.
Old 07-18-2011, 11:25 AM   #20
thirdstreettito
Resident of Here
Re: New Guy here...
Lol, no I mean these. The billet type things the wire go through. In these pics-
~Bradley~
Miss having a truck
Old 07-18-2011, 12:05 PM   #21
jblaven
Summit calls them Billet Wire Looms...
Part # SUM-440320
...but if you have center bolt valve covers, you need the adapter kit:
Part # 69600
Old 07-18-2011, 02:25 PM   #22
thirdstreettito
Resident of Here
Re: New Guy here...
Thanks!
~Bradley~
Miss having a truck
Old 07-27-2011, 06:24 PM   #23
jblaven
Almost ready to install new 350...
Getting ready to install the new engine... Man was the garage a mess. I made some panels for my utility trailer... A huge help loading up the wife's school boxes (in one load)
I stirred up so much dust I think I made myself sick... about to have a temperature of 100. Yeah, yeah, I know...
Anyway, I think I am about ready to dive into the swap within the next day or two.
Old 07-28-2011, 11:25 PM   #24
jblaven
Re: New Guy here...
Old 07-28-2011, 11:34 PM   #25
SBTork
Garage wrench
SBTork's Avatar
Re: New Guy here...
cool. It looks to be lined up and ready for a motor swap.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
