07-25-2011, 08:56 AM | #1 |
91 S10 rearend swap
what rearend are people using in S10 for drag racing? the truck has a 7.5 10bolt, is it strong enough for the strip or will it just rip it self apart? also its not a posi and would like to make it one.
Jared 2014 Ram 2500 powerwagon 2006 GSXR 600 2012 Arcticcat proclimb 800 1970 C10 SWB 5.3LS turbo and 4L60E "all throttle no bottle" "Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences" "its not turbo lag, its for play" |
07-25-2011, 12:59 PM | #2 |
Re: 91 S10 rearend swap
You can eithor grab a S10 8.5 10-bolt, or grab a ford 9 inch rearend.
07-25-2011, 01:57 PM | #3 |
How can you tell the differance between the two rearends? the 8.5 and the 7.5?
07-26-2011, 07:31 AM | #4 |
Get a 9 inch if you think you ever want to go fast!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-26-2011, 12:59 PM | #5 |
http://www.oldspower.com/vb/showthread.php?t=31398
Instead of the two points at the bottom of the Differential, you will have "squared off" tabs |
07-26-2011, 04:56 PM | #6 |
how are the ford 8.8 for strength? i found a complete rear end with 4.10 ratio and disks brakes for 1000 is that a good price? and its already sized up for an S-10.
07-26-2011, 05:03 PM | #7 |
also i heard that a Nova rear end will bolt right in. Do you guys know what other 10 or 12 bolt cars will bolt into an S-10?
07-27-2011, 12:03 PM | #8 |
mini truck racer
The 8.8 will go in if you narrow the long side 3 inches and run 2 short side axles . I think ( dont quote me ) it comes out like 56 inches and the stocker is 54.5 . You'll need a bigger offset to make it work .
Personally , i would build a 9" . You can buy 33 spline axle and spool package from moser and use a stock case if your on a budget , but i suggest going 35 spline as the axles are basically the same price .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-27-2011, 01:23 PM | #9 |
You can run 35 in a stock case you just have to have the right spool. Mark William was the only one that would work 20 years ago but i'm sure there are others now.
08-06-2011, 12:33 AM | #10 | |
BTW, thats a hot setup for the rear end in Jeep Wranglers, so if you know any jeep guys they might be able to help you find one.
'76 C10 "BIG10" SWB 454/400 Mostly Stock. |
08-06-2011, 10:17 AM | #11 |
go to the junk yard with a measuring tape, after you've measured the s-10 spring mounts..
fyi.. exployer and rangers that have 8.8 rear ends , fall in. and the 8.8 is as strong as a 12 bolt (almost a copy really) |
08-07-2011, 09:38 AM | #12 | |
How fast are you trying to go? 2) P.S. i think Moser and others offer complete bolt in 12 bolts for the s-10 but that's big money (2K). i think you can get more use out of a 7.5 10 bolt than what is commonly thought. |
08-07-2011, 01:50 PM | #13 |
Two words. Nine inch
08-07-2011, 04:31 PM | #14 |
Depends on power level but I suggest the Explorer rear(8.8), c clips though or the venerable 9"
08-07-2011, 08:10 PM | #15 | |
I'd think there wouldn't be any "offset" |
08-07-2011, 08:34 PM | #16 |
For some reason the pinion is way offset in the explorer 8.8's I would not run it the way it comes in a performance application.
08-07-2011, 08:47 PM | #17 |
this ^^^ if you're goin to the trouble to fab in a different rear end. make it worth your trouble if you can find a direct bolt 8.5 for cheap then that wouldn't be bad if you're just building a moderate performer |
