Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-29-2011, 03:41 PM   #1
McMurray76
Advantage 52
What is the advantage of running 52" leaf springs on the front?
McMurray76 is offline   Reply With Quote
Old 07-29-2011, 03:43 PM   #2
McMurray76
Re: Advantage 52
Old 07-29-2011, 05:50 PM   #3
ncgamedog
Re: Advantage 52
budget 4" lift, softer ride quality than standard lift spring, moves axle forward a bit, and keeps a more appropriate shackle angle.
there are some cons too, but you didn't ask abt that...
ncgamedog is offline   Reply With Quote
Old 07-30-2011, 07:56 AM   #4
madcow75
madcow75's Avatar
Re: Advantage 52
Okay ...ncgamedog.. I will ask then what are the cons then.
madcow75 is offline   Reply With Quote
Old 08-01-2011, 12:34 AM   #5
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Advantage 52
K... I wanna know too. I have been going back and forth on 52s since I need to replace my front spring hangers. It will either be 52s or whatever length is on my 91.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 08-01-2011, 06:59 AM   #6
madcow75
madcow75's Avatar
Re: Advantage 52
91.... are you sure you don't have 64's or 56's.
Old 08-01-2011, 10:36 PM   #7
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Advantage 52
No my fronts are 46 or 48's or something like that. They are long!
-Jeremy
Rebuilding an NP205
Old 08-02-2011, 02:48 PM   #8
McMurray76
Re: Advantage 52
What are the cons?
What is the best way to level out the rear?
Old 08-02-2011, 03:54 PM   #9
ncgamedog
Re: Advantage 52
Originally Posted by McMurray76 View Post
What are the cons?
It depends somewhat on what model vehicle your thinking about running them on. For blazers, which obviously have a fairly short wheelbase, it can cause some significant body roll for on-road driving. That depends a lot on your comfort level driving a teeter-toter rig. I ran them on a 78 k5 and enjoyed them offroad but it added some pucker factor when hanging curves. I ditched the factory overload from mine and added a cut down leaf from another pack. Not counting the overload, there are 4 and 5 leaf versions. Mine were the 5 leaf, and I would highly recommend those. There is also an issue with some axle wrap in the front when using these, due to the added length and soft spring rate. Once again, its all in what you can live with. They certainly aren't as bad as some RUF applications I have seen, such as folks running toyota rear springs in the front of their SAS swaps. Rear springs, in general, are designed differently than front springs. Rears typically have a lager transition in length from leaf to leaf as they progressively step down. That's why when you see custom made front leaf packs they usually have a high leaf count and use thinner leaves. On a truck the negative effects should be less noticeable, but not completely. They are certainly a viable option, and a good one for budget minded wheelers. If its primarily a daily driven rig, then you may disappointed in the change in handling. You could also investigate running a sway bar, by either modifying the factory one or some other custom option.
Shackle flip for the rear!
http://diy4x.com/cart/index.php?rout...product_id=112
http://offroaddesign.com/catalog/shacklekit.htm
Old 08-02-2011, 05:07 PM   #10
McMurray76
Re: Advantage 52
Thanks!
