where does the clutch ball mount on my 454?
my truck is factory SBC and i am converting it to BBC. don't everything correctly so far and now i have a major issue because i am moving and need it running and driving.
there was a bracket on my SB that bolted to the block above the oil filter. on my BB there is one hole for a clutch ball above the oil filter? does it use the same Z-bar location? need HELP thanks so much folks!!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear! 1969 C30 Open Road Motorhome 350/th400 1972 K10 350/350/205 Daily Driver -SOLD |
Re: where does the clutch ball mount on my 454?
pictures would help a TON!!!
Active Member
![]() Join Date: May 2009
Check out post #5 here http://67-72chevytrucks.com/vboard/s...d.php?t=334035
Also not sure what your SB one looks like but here is one I saved from a 402. I know this isnt the for sale board but let me know if you need it. Last edited by fredm98; 08-01-2011 at 10:54 PM. |
Junior Member
I got the one for my 454 from Auto Tire and Parts (Napa). It was a ball with a threaded end.
The way we mounted the engine we did have to move the mount on the frame to get a good angle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
![]() Join Date: Aug 2005
The zbar from the SBC should work, one did on my BBC. The angle may be a bit funky as mentioned above. You may need a bracket or you may be able to use the threaded hole in the block. Its kinda one those deals you wont know till you get the engine and trans stabbed in there. Another Idea I kinda kick myself for not doing is a conversion to a hydraulic throw out bearing. Smoother clutch feel and elimantes the angles and parts. While I'm not a fan of LMC parts, their catalog has a great view of all the parts needed for the z bar set up
fredm98 i would love to purchase that! pm me your info and a price!!
hmm... i can't wait to tackle the clutch linkage on my BBC/4x4 conversion.
Yeah your gonna have so much fun!
Junior Member
I bought the clutch ball that screws into the block of a 454 at Auto Tire and Parts/Napa for around $12. The item number is 615-1197.
Just thought this might help some one some day.
did it line up with the Z-bar?
I'm getting ready for that conversion now any pointers..
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
