Old 08-04-2011, 04:23 PM   #1
jblaven
Question '88 Burb - What sensor is connected to the starter?
There is a wire running to the engine block just in front of where the starter is mounted. This sensor is wired to the starter. Which sensor is this?
jblaven is offline   Reply With Quote
Old 08-05-2011, 04:15 PM   #2
jblaven
Here is a pic...
I guess it is a sensor.
I did notice that the wire was nicked:
I wonder if someone sells a starter wiring harness.
Old 08-05-2011, 09:08 PM   #3
burb1085
burb1085's Avatar
Re: '88 Burb - What sensor is connected to the starter?
That is the knock sensor. It retards the timing if it senses detonation.
burb1085 is offline   Reply With Quote
Old 08-05-2011, 09:52 PM   #4
jblaven
Ah, Thanks!
Old 08-05-2011, 11:15 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep x2. I would just wrap that wire unless its bad and splice it and crimp it up and call it good. Just need to make sure its not touching any metal with the bare wire.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
