Driveshaft problems please help
I have a '72 C10 350/TH350 LWB. Twice in the past few months I have replaced the carrier bearing and twice it has completely ripped the mount apart. The driveshaft doesn't have any obvious vibrations. Only when excelerating from a stop.
Help please. Posted via Mobile Device |
Newbee
Re: Driveshaft problems please help
Take the shaft to a driveline shop and have them ballance it, and check it for straight. It doesn't take much to really mess things up.
I had a problem similar to yours and it turned out to be the rubber isolator (see Posts #72-74 in my Project thread for details)
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
![]() Join Date: Oct 2005
Your U-joints are probably out of phase.
Is there a dent in your driveline? If it has a dent your driveline is bent (not straight). Vibration under acceleration suggests you have a problem with driveline geometry. There is a lot of great information on drivelines on the Spicer web site.
#6 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
You didn't say if your truck has been lowered, but if it has it could be your pinion angle. Several companies offer wedges that correct the pinion angle. Usually a 3 or 4 degree wedge will tilt the pinion angle down enough to compensate the lowered stance.
If the ride is stock, I would agree with all of the above replys. NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
Have a slip yoke put in the rear shaft.
the boat guy
sounds like the shafts are out of time. Sounds like a trip to the driveine shop to hae tem put on a carrier bearing, put the shafts back in time, check ujoints and ballance.
low speed vibration is from angle or phasing prolems. A bent shaft viration will usually start around 45mph |
