Old 08-07-2011, 09:05 PM   #1
sourkraut
sourkraut's Avatar
High hump/cab floor seal?
was wondering what you guys have used after installing a high hump for a gasket or seal? thanks in advance
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 08-08-2011, 12:42 AM   #2
dan42
dan42's Avatar
Re: High hump/cab floor seal?
I think I just used a silicone sealer - I don't plan on taking it off anytime soon. a strip of neoprene/window type sealer glued all the way around would work. Just something to keep out the moisture and the noise.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-08-2011, 01:29 AM   #3
vectorit
What?
vectorit's Avatar
I use a good bead of RTV sealant.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-09-2011, 01:49 AM   #4
cheyenne shortstep
cheyenne shortstep's Avatar
I would not recommend silicone as it is prone to hold moisture and cause rust. A urethane based sealer, such as windshield sealer is a safe bet as it is more likely to repel moisture. I used butyl tape on mine.
cheyenne shortstep is offline   Reply With Quote
