Old 08-08-2011, 07:29 AM   #1
MagmaJct
MagmaJct's Avatar
Non-foulers or Hotter Plugs
I've got two cylinders that take in oil from an unknown source. I don't have the money for a rebuild, I put about 3,000 miles/year on my truck, and it still passes emissions. So this is a problem I'll have to live with for now.
The two spark plugs in these cylinders tend to foul pretty badly. I'm considering either non-foulers or hotter plugs to burn off the extra oil. In fact, I'm considering doing one, then the other as a test of which is more effective.
Who has had experience with either non-foulers or hotter plugs? What results did you see?
MagmaJct is offline   Reply With Quote
Old 08-08-2011, 08:35 AM   #2
cdowns
cdowns's Avatar
Re: Non-foulers or Hotter Plugs
stopgap solutions at best neither will holdup for long
Old 08-08-2011, 09:19 AM   #3
bigsnookmaster
bigsnookmaster's Avatar
I had a small block with a couple non foulers in it. They worked ok, and when they started fouling again, I'd just take them out and clean them. I also kept a couple of extra plugs and a plug wrench setup in my truck with me just in case.
bigsnookmaster is offline   Reply With Quote
Old 08-08-2011, 09:31 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
We run no foulers in our old Jubilee F*rd tractors and they work ok. Like stated above they would only be a stop gap on a vehicle that is driven more often.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-09-2011, 07:27 AM   #5
MagmaJct
MagmaJct's Avatar
Thanks all. I'm going to see if I can find the source of the oil. Considering the few miles per year I put on the truck, and having no money, I don't mind stop gap measures. It's not like I depend on this truck.
Old 08-09-2011, 07:35 AM   #6
MARKDTN
I would look at some new valve stem seals. That would be very inexpensive. They may not last long, but with the mileage you are doing might help. Anti foulers are not a very effective solution. I would put in HEI before I did them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-09-2011, 08:05 AM   #7
It probably is the valve stem seals. Is it the rear plugs? Does it smoke when you start it?
Old 08-09-2011, 07:07 PM   #8
MagmaJct
MagmaJct's Avatar
Only 1 & 3 get fouled up with oil. I've done a compression test and the results were in spec according to Chilton. The left exhaust does smoke lightly when the engine is cold. I'll take a look at the valve stems the next time I have free time to pull the cover.
Is there a way to determine where the oil is entering the cylinders from?
Last edited by MagmaJct; 08-09-2011 at 07:17 PM. Reason: Added words in blue to better define symptoms.
