Old 08-21-2011, 07:23 PM   #1
bark
wire problems
ok, Ive built my harness using info from lt1 swap, I'm in mock up stage on my dbw 6.0l in a 76 stepper, I hooked it all up my pump ran for a second and my throttle body did a search phase, then has a kinda hum whistle sound to it, but does not open or close with throttle, also when I hook up my scanner It powers up but will not connect to the computer. I have not got my computer tune done yet, so not sure if that is why its not working, was just kinda hoping to fire it (not run, just fire. I know vats won't allow it), before I tear it all down for paint????
did I do something wrong, or will I have to wait for a tune before I bother trying?
thanks
bark is offline   Reply With Quote
Old 08-26-2011, 12:05 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: wire problems
I'm not certain of this....but didn't think the DBW throttle bodies took input from the pedal until the engine starts? As far as the sound....don't have a clue. scanner shouldn't require a tune to activate?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-26-2011, 04:13 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: wire problems
Everything sounds right. You can try to start it with VATS but it will pop a few times and die or maybe run for a few seconds.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-27-2011, 02:47 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: wire problems
if vats is in it will turn over but will usually die before it catches. IF your fuel system is primed it will catch and fire a few *chugs* but die again. If your engine is non-stock, the pcm needs to "learn" the setup a bit so it probably won't catch.
I think 68GMC is right, the tb won't respond until its running, except for the test "Sweep" from key on.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-14-2011, 01:47 PM   #5
bark
Re: wire problems
been really busy around here, so havent had much time to work on it. I checked my daily driver (03 silverado) and with the key on if you step on the go pedal the TB will open, so? I will have to go throught my wireing, I`m hopeing it might just have a ground problem
Old 10-02-2011, 10:48 AM   #6
bark
Re: wire problems
so I got some time, I did some digging on my harness, and found that I missed a ground on the back of the engine (there is more then one), as soon as I hooked it up, hit the key the pump primed up. I cranked and it fired and died, then all of a sudden my scanner decided to link to the computer???? and I had an intake pressure code and bad MAF, grabbed another MAF erased codes, hit the key and it RUNS!!!!!!! found out that workhorse delivery vans don't have VATS
Now the only issue is my intake pressure code keeps coming back, which disables my DBW TB, as soon as I erase it, the throttle will operate for a bit????
have to find out more about intake pressure code, but it runs, so now its time for tear down and PAINT.... YAY!!!!!!
Old 10-02-2011, 06:19 PM   #7
clinebarger
Re: wire problems
Whats the code number?
clinebarger is offline   Reply With Quote
Old 10-02-2011, 08:26 PM   #8
bark
Re: wire problems
hmm I think it was p0107???
not sure tho will have to re scan it, cause I guaranty it will be back.
Old 10-05-2011, 10:41 AM   #9
clinebarger
Re: wire problems
P0107...MAP Sensor Circuit Low Voltage.
Possible Causes.
MAP sensor connector is damaged (check pins for damage, and for moisture)
MAP sensor signal circuit is shorted to ground
MAP sensor 5 volt circuit open between the sensor and PCM
MAP sensor has failed
PCM has failed
Check the MAP sensor voltage, Key On Engine Off.
Should have close to 5 V when near sea level.
Check the MAP sensor connection at the rear of the intake manifold.
Old 10-08-2011, 12:45 AM   #10
mcbassin
Still Learning
mcbassin's Avatar
Re: wire problems
since your engine PCM doesn't have VATS does this mean you didn't have to have it re-programmed? You know what vehicle your donor came from?
mcbassin is offline   Reply With Quote
Old 10-09-2011, 11:02 PM   #11
bark
Re: wire problems
Ya it's from a cube van, a 2005 workhorse still need to get a burn, cause I got rid of the emissions
