Old 08-27-2011, 01:47 AM   #1
LCWARRIOR
LCWARRIOR's Avatar
5 lug rearend conversion
Hello! My name is steve and im knew to the 67-72 truck scene. Im wanting to convert my truck from 6 lug to 5 lug only because im hooked on the torque thrust wheels and want a set bad. What would be the best and easiest rearend to install without alot of modifications? My truck is a 69 c-10. What year make and model should i be looking for? Hope someone can help thanks!
1962 IMPALA SS RAGTOP
1962 IMPALA HARDTOP
1952 CHEVY TRUCK
1971 CHEVY K5 BLAZER
1969 CHEVY C-10 TRUCK
1992 CHEVY 4X4 BLAZER (2 DOOR)
LCWARRIOR is offline   Reply With Quote
Old 08-27-2011, 02:21 AM   #2
454stepside
Re: 5 lug rearend conversion
its easies to stick with 67-72 chevy parts but you can use anything but if your truck has trailing arms you will need to use the piece that bolts the rear end to the trailing arm off your rear end or buy the new piece to weld to your new rear end or if needed i have a 5 lug rearend from a 71 chevy pickup to sell not listed yet but you can pm me to talk about it and we are not that far away from each other
454stepside is offline   Reply With Quote
Old 08-27-2011, 08:59 AM   #3
mrhino
The easiest is to buy a new set of axles from moser engineering and just slide them in and your done(20 Mins). The cheapest would be to have your old axles re-drilled (if their any good) by a machine shop, or send them to Moser for redrilling thats it. short of swapping a whole rear end, and that be stupid unless you got the whole rear cheap, you knew that rear was good, u will probably new u bolts, and a weekend to put it in. just not worth all the hassle
mrhino is offline   Reply With Quote
Old 08-27-2011, 10:19 AM   #4
Red68
Red68's Avatar
I converted mine from 6 to 5 by swapping the axles as mrhino suggested. I purchased mine from Classic performance products (CPP)
http://www.classicperform.com/Store/.../6369RAC-5.htm
Easy swap, I also added 17" torque thrust II's at the same time.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 08-27-2011, 03:39 PM   #5
LCWARRIOR
LCWARRIOR's Avatar
Thanks for all the info! Ill start doing my home work now!
1962 IMPALA HARDTOP
1952 CHEVY TRUCK
Old 08-27-2011, 04:42 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Get conversion axles.
Then add 71-72 5-lug brake drums.
Keith
Convert to disc brakes.
Old 08-28-2011, 10:29 PM   #7
LCWARRIOR
LCWARRIOR's Avatar
Ttt
1962 IMPALA HARDTOP
1952 CHEVY TRUCK
Old 08-28-2011, 11:40 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
i good a good already painted 5 lug rearend from a local member who swapped rearends for diff gear ratio..
thanks again matt gave 150 for it, and it oughta hold up good for quite some time i hope. already had new u bolts so i just needed gear oil and swapped my brakes over (new on the 6 bolt)
John
1999 Toyota Tacoma 4x4
Old 09-20-2015, 03:19 PM   #9
Razr
I know this is old, but will the axle swaps work on a 1969 3/4ton 8 lug. I want to go to 5 lug.
Razr is offline   Reply With Quote
Old 09-20-2015, 04:49 PM   #10
lolife99
lolife99's Avatar
No.
Completely different rear axle assembly.
Keith
