Old 08-28-2011, 08:05 PM   #1
2dwn4u
back on the 1950 after 10 yrs being stopped
10 years ago my cousin purchased a 1950 chevy truck, which belonged to my parents neighbor(Manuel) down the street. Manuel had owned the truck for many years and it had been a big part of there family. When my cousin John purchased the truck it came with a camaro subframe already installed, the cab was already painted in a solid medium blue looked really crappy. John then decide that he wanted this truck to be on the ground so he ordered up a set of airbags for all four corners and had a four link installed in the rear by Brian Smith (http://www.lilbrimotorsports.com) at the time Brian was a fabricator for Lenards custom mufflers. John started doing some body work and installed a motor in it , then the project came to a stop, after purchasing a home and getting married the truck was put away for many years 10 years to be exact. I also had been away for many years we then hooked up again and decided that it was time to bring the 50 out and get it started all over again, so here we are its now 2011 and alot has changed, So we have decide that we are going to be making alot of changes on the truck I will be posting pictures of the build here so stay tuned. I am in the process of looking for pictures from 10 years ago but in the meantime I will post what we have now.
2dwn4u is offline   Reply With Quote
Old 08-28-2011, 08:16 PM   #2
2dwn4u
Re: back on the 1950 after 10 yrs being stopped
Previous owner decided to put alot of coins into his project. Hagan door hindges are installed.
Old 08-28-2011, 08:33 PM   #3
2dwn4u
some more pics
Old 08-28-2011, 09:14 PM   #4
2dwn4u
Drip rails are leaving they are only good for one thing right now...=)
Old 08-28-2011, 09:36 PM   #5
youngrodder
youngrodder's Avatar
I like the way you think.....I also removed my drip rails. I like how it makes the cab look more round and smooth without them.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 08-28-2011, 09:38 PM   #6
mrchevy1950
Hey George, looks familiar. Here is my cab.
mrchevy1950 is offline   Reply With Quote
Old 08-28-2011, 09:40 PM   #7
mrchevy1950
1 more
Old 08-28-2011, 10:14 PM   #8
2dwn4u
Marc,
Is that your black and green truck? Love the color combo!!!
Marc
Old 08-28-2011, 10:19 PM   #9
2dwn4u
Earl,
Yeah looks alot like our project here. Hey did you chop you top?
Old 08-28-2011, 11:25 PM   #10
mrchevy1950
No all stock
Old 08-28-2011, 11:28 PM   #11
2dwn4u
we just realized its been 13 years these next pictures are the ones we found when it came back from getting 4 linked
Old 08-29-2011, 09:15 PM   #12
Wheelie
This thing is going to be low, very cool!
Wheelie is offline   Reply With Quote
Old 08-29-2011, 09:57 PM   #13
youngrodder
Originally Posted by 2dwn4u View Post
Marc,
Yes, it's mine. It has a 12 year project, so I can commiserate with you on your build. Thanks for the compliment.
Marc
Old 08-29-2011, 10:07 PM   #14
2dwn4u
Yeah its pretty low, the running boards were moved up 1" and the front fenders have been also cut near the running board. this truck lays running boards we will be posting pics when we start getting it all back together before paint, but right now we have alot of work going on the cab.
Old 08-30-2011, 12:29 PM   #15
duwem
duwem's Avatar
What are Hagan door hindges?
duwem is offline   Reply With Quote
Old 08-30-2011, 09:47 PM   #16
2dwn4u
Hagan is a brand of hidden door hindges its looks alot cleaner then the originals no ugly bolts in the door jamb, its alot of work though .
Old 08-31-2011, 01:12 PM   #17
duwem
duwem's Avatar
Do you need to remove the outer cab sheet metal to install them? Are they universial fit or is there a kit for our trucks?
Old 08-31-2011, 10:21 PM   #18
2dwn4u
We removed the panels because we were replacing them anyways but you can install them without taking out the panel but it makes it alot easier to brace the hindges,and to etch the bare metal with out that panel installed.
are you building a truck also?
Old 09-04-2011, 01:32 AM   #19
2dwn4u
here are some more pics from last nights work, alot of welding still going on..
Old 09-15-2011, 01:26 PM   #20
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good man. Keep the pics coming.
Kabwe is offline   Reply With Quote
Old 11-12-2011, 02:05 PM   #21
2dwn4u
haven't posted any pics lately because alot of welding and grinding has been going on, we ended up welding all the seams in the door jambs, and stitch welded the floor into place from underneath. We are now in the process of gaping all the door gaps and installing the bear claw latches which i will post some pictures later on .
Old 12-20-2011, 04:50 AM   #22
2dwn4u
Well here we are again,,,,all the welding on the cab and doors are finally done installed the baer claw latches , today we epoxy primered the bottom of the cab, before we get started on the bodywork on the cab, which is about to happen within these next couple of days.
Old 12-20-2011, 07:17 AM   #23
fat56
fat56's Avatar
looking good mate.. makes a big difference without them drip rails, alot smoother.
Blake. Sydney Aus
56 Chev 3100
build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363
LOW n LOUD
fat56 is offline   Reply With Quote
Old 12-20-2011, 08:37 AM   #24
duwem
duwem's Avatar
Cab's looking good!
Here is my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=435302
Funny how my drivers door has been overopened and has the same crease as yours with the holes from a puller! I'm going to replace that pannel. Any tips?
Old 12-29-2011, 11:18 PM   #25
2dwn4u
Cab's looking good!
Here is my build:
Just seen your build,,, that chassis is looking bad ass!! keep up the good work, what is going to be the ride height?
