Old 09-06-2011, 03:26 PM   #1
1966Stepside
1966Stepside's Avatar
Reusing Turbo 350 X-Member issues
I started to finish up my 5.3/4l60e swap by getting the transmission x-member in place and the tranny bolted to it. My truck previously had a 350/350 combo from the P.O. To save a few bucks, I wanted to see if I could reuse the old crossmember with new hardware.
When I went to look and see if the old Turbo 350 xmember would work, it seems to be a pretty darn near perfect bolt in for the xmember's stock location, but the Transmission Mount I'm using (single bolt style) Seems to be about 3/4 to 1 inch toward the driver's side from the original bolt hole in the mount. I checked the alignment of my motor and it seems to be in right, so is this something normal? I plan to take some measurements underneath the truck at the tailshaft to see if the transmission tailshaft is off by 3/4 to 1 inch or what the deal is. Has anyone else had this issue?
1966Stepside is offline   Reply With Quote
Old 09-06-2011, 04:29 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Reusing Turbo 350 X-Member issues
Mine did the same thing, so I went with this..
http://www.classicperform.com/Store/...uck/CP9427.htm
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-06-2011, 06:17 PM   #3
1966Stepside
did you use the factory mount with that?
Old 09-07-2011, 11:15 AM   #4
Shon
I am using the stock TH350 mount moved back with my 4l80e.
used the stock holes in frame.
Used stock 4l80e trans mount and elongated hole.
stock motor mount with transdapt plates.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-07-2011, 11:18 AM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I also used a $6.50 TH350 mount (2 bolt style) with the factory cross member. I did need to drill new holes in the frame because I moved the cross member back.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
