09-06-2011, 04:32 PM | #1 |
Junior Member
A-Arm Swap
Just wondering, I have a set of arms and cross shafts off a 85. Will these bolt right up to my 69 or do i need the mounting brackets off the 85 also?
09-06-2011, 04:52 PM | #2 |
Re: A-Arm Swap
They'll swap over. The cross shaft is different starting in 73 & requires the convex type washer on one side of the shaft (both studs).
09-15-2011, 06:36 PM | #3 |
Junior Member
Re: A-Arm Swap
can you purchase these? I wasnt given them with the arms and cant seem to find a listing on them
09-16-2011, 12:11 AM | #4 | |
Re: A-Arm Swap
