Old 09-06-2011, 11:30 PM   #1
gpat@earthlink.net
Active Member
72 Frame tails measurements
Can anyone send me the measurements from the tip of rear frame tails to the cross support at the gas tank? Trying to put the original bumper back on.
I also need the location of the body mounting bushing distance from rear tip. I have replacement tails but don't know the length. Thanks for your help. Pat
gpat@earthlink.net is offline   Reply With Quote
Old 09-07-2011, 12:47 AM   #2
kcsa75
kcsa75's Avatar
Re: 72 Frame tails measurements
This should give you what you need.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 09-07-2011, 08:13 AM   #3
gpat@earthlink.net
Active Member
Thanks Willie. Do you have a measurment from the overall point of 199.24 back to the mounting holes that measure 33.95 wide or either from 199.24 to the tip. Mine is a 4 wheel drive model . i assume that is the top frame on you schematic. Pat.
Old 09-07-2011, 08:16 AM   #4
gpat@earthlink.net
Active Member
Just got it 12.6. I' ll split the difference for the holes. Thanks Pat.
Old 09-07-2011, 09:35 PM   #5
gpat@earthlink.net
Active Member
Can someone send a picture of the rear frame tails 72 4 wheel drive model.
The replacement tails I have, have different angles at the tip. I don't know if they are bent on not.
Old 09-09-2011, 10:48 AM   #6
SleepyK5
So GM made two frame styles for blazers? What is the difference besides the length? I have one of both styles and I want to put a beauty bumper on and not a step bumper. Can anybody help me?
SleepyK5 is offline   Reply With Quote
Old 09-09-2011, 11:14 AM   #7
1949gmc
Hey Pat- Do these help you at all?
1949gmc is offline   Reply With Quote
Old 09-09-2011, 11:17 AM   #8
1949gmc
SleepyK5- 69-71 Blazer frames need an inner bumper bracket bolted to the frame to use a sport bumper. In '72, they changed the frame horns so that the bracket was not needed; the bumper just bolts right to the frame.
Old 09-09-2011, 11:49 AM   #9
SleepyK5
It looks like they r cut off on my 70 just behind the rear body mount. Is that how they were in 70 then they changed them in 72. Just trying to make sure I understood u correctly.
Old 09-09-2011, 12:19 PM   #10
1949gmc
Yes, that's exactly what they look like. Just like they got sawed off behind that mount. This is what my '71 looked like. You see the clean spots on the sides of the frame rails right under the last mount where the bumper brackets were.
Old 09-09-2011, 01:21 PM   #11
SleepyK5
Great I really appreciate your help. Any suggestions on exhaut headers for a big block 4x4 with manual tran?
Old 11-05-2012, 07:04 PM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing up a thread to see if I can get a measurement... Can someone take a square and measure the height of the frame right in front of the body mount? I made a red line on the picture where I'm talking about. I was looking to have it accurate to within a 1/16" of an inch. I have a 72 frame and I want to compare the older style to what I have.
Rich
1972 K5 Blazer CST Click HERE
