Old 09-23-2011, 09:54 PM   #1
innoi
Can I do anything?
I have a Dana 44 closed knuckle front end. Steering sucks on my truck 67 GMC 4x4 longbed, its lifted. Is there anything I can do to get better steering. Besides swapping out axles. Im not opposed to doing an axle swap but would want to find one that didn't have me changing all kinds of stuff out to make it work. Any thoughts ??
innoi is offline   Reply With Quote
Old 09-23-2011, 10:36 PM   #2
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Can I do anything?
Take the leap and install an open knuckle Dana 44 front into your truck..you wont regret it! youll get much better turning radius and better braking..plus have an axle thats much easier to work on and get parts for.
Its pretty much a bolt in deal and depending on how much lift you have there wont be much of changing other parts..I would suggest a raised steering arm if your using 4" or more of lift..and find yourself a 71 -72 brake booster and prop valve from preferablly a 20 series truck.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 09-23-2011, 10:41 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
X2 Thats exactly along the lines of what I was going to suggest. If you do the swap you might as well replace all your worn out steering components that need it as well!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-24-2011, 10:29 AM   #4
mud slut 350
mud slut 350's Avatar
crossover steering will turn a lot better
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
Old 10-24-2011, 10:43 AM   #5
Redcap
Not on a closed knuckle.
Redcap is offline   Reply With Quote
Old 10-24-2011, 10:47 AM   #6
mud slut 350
sorry didnt know much bout closed knuckle 44s (had to google it) lol swap to a open one and go crossover then
2007 cbr 1000rr
