Old 09-24-2011, 12:02 AM   #1
rjsdad
rjsdad's Avatar
Wiper arm removal?
Hey guys! How does one get the wiper arms off? Not too sure how to do it and don't want to break them. Thanks!!
Jeff
rjsdad is offline   Reply With Quote
Old 09-24-2011, 12:15 AM   #2
vectorit
What?
vectorit's Avatar
Re: Wiper arm removal?
I just use a flat screw driver with the steel cover with a rag or electrical tape, then I place a block of wood protected as well for the paint to use as a fulcrum.
I then pry up gently from the rear of the wiper arm, since it is under tension this seems to be the best place to pry up on.
be sure to wrap the arm with a T shirt, because once it pops off it will jump up and land on the hood. So wrapping it in cloth will keep it from chipping the paint, or causing some other kind of dings.
Keep in mind to, that if it hasn't been off in 40 some odd years it will take a lot of gentle prying. Since the arm piece that is pressed onto the gear is made of pot metal, and the gear is made of steel and the two could be corroded together. If it seems stuck on, try bending a WD-40 tube under there and squirt is down a bit and let soak.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-24-2011, 11:25 AM   #3
rjsdad
rjsdad's Avatar
Thanks so much. I'll give that a shot. I wasn't sure if it had a clip like the door handles. I thought it looked like it and I didn't want to break anything since it's going to rain all next week.
Jeff
Old 09-24-2011, 11:01 PM   #4
burbguy77
burbguy77's Avatar
there is a tab on the back that locks them on.
burbguy77 is offline   Reply With Quote
Old 09-25-2011, 12:31 AM   #5
vectorit
What?
vectorit's Avatar
That is correct, there is a tab that "locks" the arm on. But it is just a thin spring steel tab that flexes, and not all wiper arms have this lock tab and just rely on tension of the arm to keep it on.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-25-2011, 10:40 PM   #6
haskell
haskell's Avatar
I have found the tab is rounded enough that it will not keep the wiper on if you are applying pressure per vectorit with a covered large screw driver and a block of wood for sheet metal protection.
1969 Chev Longhorn Custom Camper
1955 Buick Century Estate Wagon
1963 Buick Riviera
1953 Chevy 3100 Panel
1967 C-20 V8 4 speed
1951 Willys Jeep Wagon
1956 Chevy Suburban
haskell is offline   Reply With Quote
Old 09-26-2011, 10:39 AM   #7
Steven B
Steven B's Avatar
NAPA has a handy tool to remove wiper arms.
70 Jimmy 4x4
71 GMC 2500
Too bad stupidity isn't painful
Steven B is offline   Reply With Quote
Old 09-27-2011, 02:39 PM   #8
rjsdad
rjsdad's Avatar
Thanks guys! Got them off fairly easy after some WD40.
