Old 09-24-2011, 09:04 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Grant Steering wheel install issue
I got a Grant 969 classic steering wheel yesterday. I also got the 3162 install kit, according to Grants website. Truck is a '69 C10.
I can not get the horn cap to attach to the plate. The instructions say to line the dimples up in the cap with the notches in the fiber plate. There are no notches in the fiber plate.
I can not get the cap to stay on the plate with the spring installed.
Any ideas?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-24-2011, 02:30 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Grant Steering wheel install issue
Well there should be small notches on the edge of that fibre plate thingy, if not you should send it back for replacement, alternativly mark where the dimples are on the horn button onto the edge of the plate and use a small file and create your own.
Once you put the spring on the column nut you line up the dimples push down on the horn button and twist it on
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 09-24-2011, 02:32 PM   #3
dukcaln
dukcaln's Avatar
hope you can get the horn to work, mine never did......
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 09-24-2011, 02:44 PM   #4
OJ1988
Just a car guy
OJ1988's Avatar
This is the install kit I got,
http://www.grantproducts.com/products/view/240/
Notice in their pics there are not any reliefs. I have emailed grant.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:12 PM   #5
eightbanger
454 MAKES IT ROAR
I think it is saying something about Challenger models only have the indents for horn button removal.
http://www.grantproducts.com/files/i...524-00-01b.pdf
I bought the Classic Nostalgia wheel so it came with everything included...I think the Classic & Challenger series come with the dimples on the disc.
Nigel.
No more pain.
Old 09-24-2011, 03:17 PM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Here are the instuctions for the kit that I have.
http://www.grantproducts.com/files/i...7508-00-01.pdf
12. Remove shoulder bolts and reinstall same through
retainer contactor ring so that the fiber side is toward
you. Tighten shoulder bolts, connect wire lead to retainer.
13. Position spring on nut (you may find tape a help). Place
horn cap in position by aligning dimples in cap with reliefs
in fiber material and push until dimples pass the fiber.
Turn cap left or right until tight (1/4”-1/2”).
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:23 PM   #7
eightbanger
454 MAKES IT ROAR
I don't think that 3162 install kit is the one you need, it doesn't show dimples on the one in their pic, and it says "Standard" that makes me question it.
Nigel.
No more pain.
Old 09-24-2011, 03:28 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
According to their site it is correct.
"This is the standard Grant Steering Wheel Installation Kit. These kits may be used to install all Classic Series, Challenger Series or Signature Series Steering Wheels. Each kit contains complete step-by-step instructions, a die cast hub, grade 5 hardware and matte black trim pieces."
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:29 PM   #9
OJ1988
Just a car guy
OJ1988's Avatar
When doing an application search on thir site, this is what comes up.
http://www.grantproducts.com/product...rch/#22/3/58/1
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:30 PM   #10
OJ1988
Just a car guy
OJ1988's Avatar
This is my wheel, only difference I got the one with the blue center cap with the bow tie.
http://www.grantproducts.com/products/view/114/
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:33 PM   #11
OJ1988
Just a car guy
OJ1988's Avatar
This one
http://www.jegs.com/i/Grant/470/969/10002/-1
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:40 PM   #12
eightbanger
454 MAKES IT ROAR
Confused!! I would use a round file and make the indents myself...but then I live so far away and would need to wait like another 2 weeks for a replacement.
Nigel.
No more pain.
Old 09-24-2011, 03:41 PM   #13
OJ1988
Just a car guy
OJ1988's Avatar
No problem. I was afraid I might be confused as well.
When I get home, Im going to try and make the reliefs as you suggested. I had thought about that last night when I did the install, but figured I better check to make sure I wasn't doing something wrong.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 03:44 PM   #14
eightbanger
454 MAKES IT ROAR
Good luck mate...it should be a breeze to do.
Nigel.
No more pain.
Old 09-24-2011, 06:49 PM   #15
Regular Guy
Regular Guy's Avatar
Grant does make some nice looking wheels, but the horn button and fiber plate it is supposed to attach to was a problem as well for me--on a wheel very similiar to yours I managed to get the button on, but it didn't seem secure. But it was the best it would fit.
About a month later the button popped off by itself and off the horn went, while I was parked at my kid's soccer game, of course I was in the front row closest to the field. Highly embarrassing; but at least it wasn't at 2:00 AM in the garage when it happened.
That was the only Grant I've had--but I've read on here where someone else had similiar problems with several Grant wheels. I've been partial to OEM wheels since my experience.
Regular Guy is offline   Reply With Quote
Old 09-24-2011, 07:07 PM   #16
OJ1988
Just a car guy
OJ1988's Avatar
Yeah, so I messed around with it.
I took the plate off and notched it.
I then discovered the overall diameter if the cap to large that the dimples in the cap were not deep enough to hold the cap on under the pressure of the spring.
The stock horn button has not been functional since I got the truck.
I might just leave it unhookedand leave the spring out, maybe silicone cap if needed. Unless I can mod or get another cap.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 08:35 PM   #17
OJ1988
Just a car guy
OJ1988's Avatar
So I took a cap off a moon steering wheel, and it works!
It is a problem with the grant cap.
1973 Vega Drag Car
1970 C20 tow rig
Old 09-24-2011, 09:21 PM   #18
domeier
domeier's Avatar
I inherited a Grant with my truck, and never could get the horn right. Finally gave up and went hornless. It's no big deal until you're in the parking lot at Walmart on Saturday. Like today. Almost got tapped by some old guy backing up with his eyes focused straight in front of him. I had to lean out the window and yell stop. How humiliating was that...
I gotta get a horn working. Maybe put a momentary toggle under the dash? I gotta have something. Today was too close.
domeier is offline   Reply With Quote
Old 09-25-2011, 04:16 AM   #19
Stricklinator
Stricklinator's Avatar
I have the same problem with mine; popped off on it's own a couple days after installing. I got fed up, disconnected the wire, and put the cap on without the spring. What a horrible design! I will try again someday, maybe put some silicone on it to help it stay?
Paul
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 09-26-2011, 01:36 AM   #20
domeier
domeier's Avatar
Originally Posted by Stricklinator View Post
I have the same problem with mine; popped off on it's own a couple days after installing. I got fed up, disconnected the wire, and put the cap on without the spring. What a horrible design! I will try again someday, maybe put some silicone on it to help it stay?Posted via Mobile Device
If I had any money, I'd buy me a stock wheel. I like the feel and look of the Grant, but along with the garbage horn button, it blocks out the top of the speedo when your hand is at 11 o'clock. Gets annoying moving your hand to check speed all the time.
Old 10-19-2011, 12:10 PM   #21
OJ1988
Just a car guy
OJ1988's Avatar
Turns out the bolts is the problem. The Shoulder was to short to allow the plate to sit far enough from the wheel for the cap to make contact.
I had to notch the plate myself, and leave the 3 bolts somewhat loose. I think I will put some locktight on the.
BTW, I emailed Grant, on Sept. 27. They replied saying the plate might be wrong and they were sending me another one.
I have never recieved anything from them.
1973 Vega Drag Car
1970 C20 tow rig
Old 10-19-2011, 12:25 PM   #22
eightbanger
454 MAKES IT ROAR
Glad you found the problem mate, I would contact Grant again especially as they said there was no prob sending a replacement...just chase them up.
Nigel.
No more pain.
Old 10-19-2011, 12:57 PM   #23
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Put a Grant on my truck this weekend. Everything went fine,,until,,, when we turn the wheel the horn goes off.
specialtyretail is offline   Reply With Quote
Old 10-19-2011, 01:11 PM   #24
OJ1988
Just a car guy
OJ1988's Avatar
I sent them an email with the previous ones saying they were shipping me a part. We will see.
1973 Vega Drag Car
1970 C20 tow rig
Old 10-19-2011, 01:31 PM   #25
dcasalena
dcasalena's Avatar
I had the same problem recently after replacing a turn signal switch under my grant. I think my problem was my new cancel cam wasn't sitting level (one side dipped a little lower) so when I turned the wheel, the metal ring on the low side of the cancel cam was touching the screw holding in the turn signal lever. When the metal ring touched the screw, ground completed so horn sounded. I think I had to ditch the new cancel cam and reuse the old one after a little super glue repair.
dcasalena is offline   Reply With Quote
