09-25-2011, 02:18 AM | #1 |
Today's 8 bolt versus yesteryear's 8 bolt.
Tried searching for this answer but could find it. Do the 8 bolt rims for today's Chevy 3/4 tons fit on the 67-72 Chevy 8 bolts? Thanks in advance!
09-25-2011, 12:52 PM | #2 |
What?
Re: Today's 8 bolt versus yesteryear's 8 bolt.
The lug nut size is larger on the newer 8 luggers.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
09-25-2011, 01:47 PM | #3 |
Sorry about the rookie question, just getting my 72 burb today. So inorder to put different rims on it I will have to find rims specifically made for this year of 8 bolt, correct? Any newer year 8 bolt will not fit?
09-25-2011, 02:09 PM | #4 |
What?
The only thing I know to be different is the lug nuts on the newer 8 luggers are of a larger diameter, so they will fit the bolt pattern on the old axles but you will as far as I can tell would need to upgrade the lugs on each hub to the larger size.
Someone who has had direct experience with this will chime in sooner or later.
09-25-2011, 02:14 PM | #5 |
Moderator
Newer year 8 lug wheels will fit. The lugnuts are what is different. I know a lot of members run the newer wheels on their C-20's... some have bought the correct lugnuts from E-bay. As stated above, someone will chime in with the lugnuts you will need to pick up. I think the size of the lugnuts are the same....I think the difference is in the way they seat (not 100% sure though)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-26-2011, 11:34 AM | #6 |
I believe as mentioned the lug nuts are different. The reason you need the new style lug nuts is because the center caps are attached to the new style lug nuts. I'm not sure where you would find these new lug nuts but I would start with a tire shop and go from there if it was me.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
09-26-2011, 04:48 PM | #7 |
Junior Member
I ran some on my 3/4 ton I sold. You can get lug nuts from lugnut king on ebay.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-26-2011, 05:19 PM | #8 |
So is it just the lugut that needs to be changed or is it the actual bolt? Also how do you get rims to fit good on the back with such a big hub? Do you need to get some sort of a spacer to get the rim to fit out far enough to get a center cap on? Thanks again guys!
09-26-2011, 09:53 PM | #9 |
Just a Idea. I put 2008 Dodge wheels on my 1967 3/4 ton with no problems. The rear axel in my truck is from a 72 and the studs were bigger so I could use the lugs off the dodge. When i put the disk brakes on the from the rest will fit. I like the look of them.
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
09-27-2011, 10:17 PM | #10 |
I put a basic aftermarket set of wheels on mine. I went to the tire shop locally and ordered the "narrow shank?". They go one with the special lug tool. I had no issue with these. I had the basic open style acorns prior to that and they worked well too. You can run a spacer to bring out the rear if you'd like. I haven't yet but will in the future when I find the set one wheels I like. I also bought a basic center cap from the tire shop as well. I went with the large one on the front and back so it looked the same.[IMG]IMG_20110721_103629[/IMG]
09-27-2011, 10:17 PM | #11 |
Sorry was trying to post a pic but it won't let me attach it
09-27-2011, 10:28 PM | #12 |
Added it as my profile pic if you want to check it out sorry I couldn't get it on here
09-28-2011, 01:12 AM | #13 |
I think I will be doing what Burb 71 did. Checked with a local shop today and the old guy working new exactly what would and would not work, he didn't have to look at the burb he just new. Think we will do a polished mod rim for the time being. Thanks for everything guys!
09-28-2011, 02:12 AM | #14 |
Collector of Projects
I just test fit some Hummer H2 wheels. The bolt pattern is 8 x 6.5 (same as the Dodge wheels above). The wheel studs were 9/16 and the aluminum wheels need a 60 degree conical seat.
09-30-2011, 03:44 PM | #15 |
The big reason for changing lug nuts on newer wheels are that the old trucks have SAE threads on them, newer trucks have metric lug nuts. If you want to use the original center cap that came with the newer wheel you can buy specialised lug nuts from different vendors as mentioned above.
I am actually going to use Ford F-350 Alcoa aluminum wheels on my 72 with Chevy center caps from a set of steel wheels. |
11-03-2011, 09:06 PM | #16 |
Sorry for the delayed reply, but I am new to this site. The lug nuts can be had from a number of sources, such as lugnut king. Have run these for several years, never ceases to amaze me that people still ask what kind of wheels they are!
11-05-2011, 10:53 PM | #17 |
Man, that is one sweet Burb! I had those same wheels on mine and it looked terrible. But they definitely look good on a lowered Burb.
In fact, I just stuck those rims and tires on CL. Posted via Mobile Device
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
11-05-2011, 11:07 PM | #18 |
I had to dig deep, but I knew I could find an old pic of it.
