09-25-2011, 09:48 PM | #1 |
New to site and suburban life.
Hello fellow forum peeps, I have recently purchased a 1971 Suburban for $4500 (was that a good price?). It came with the back to front ac, ps, pb, 307 with q-jet 4bbl carb, and a 700r4 trans. The body seems to be in really good shape and doesn't look like it's ever been in an accident. So far since I got it home I have found out that the advertised 350 is actually a 1973 307 engine with upgraded 4 bbl carb which was rebuilt 35k miles ago and I am currently redoing all the brakes, shocks, and replacing all the lights. I took it in for a couple of leaks and getting the ac turned over to r134 which they tested and said it holds pressure and should work fine (they added freon and said it blew cold but when I got it it was warm and I noticed the adapter they put on was loose and hissing so I'm going back for that one). There are a few things I need help on. I noticed that the fuel gauge reads 1/3 of a tank full when it is filled. Is that a gauge or a sending unit thing? Also, when I am going 45mph the speedo reads 60mph how do I fix that? Other then that it just needs restoration parts to make it pretty. I want to get to daily driver status. I have added some pics. One last thing is mirrors as it came the small mirrors but I see other burbs with the bigger ones. Do you know where I can find those? All the websites I've been to only have the small mirrors as oem. lmctruck has been my friend lately. Thanks for all the future help as I will be asking a lot of questions here in the near future.
09-25-2011, 10:24 PM | #2 |
Re: New to site and suburban life.
Here is the build sheet. The vin matches the body and door.
1971 Chevy C10 Suburban Custom Deluxe. |
09-25-2011, 11:16 PM | #3 |
Very nice Burb! Welcome to the Burb life
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
09-25-2011, 11:20 PM | #4 |
What?
Welcome to the best place on the net for a burb owner and lover!
Sharp looking burb ya have there, and I'd say you got a pretty good deal from the pictures I see.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
09-26-2011, 01:20 AM | #5 |
70+ ( Old Skool Club )
Welcome to the boards. The nicest folks on the net are on this site. Good looking Burb you have there and it should give you lots of pleasure, but you do know that they are never finished.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-26-2011, 08:04 AM | #6 |
Yeah, I would say that you got a pretty decent deal there!
As for your questions: Speedometer speed incorrect: You will need to check the speedo gearing at the transmission. Pull the speedometer cable off and remove the gear housing and see what gears you have, both drive and driven. There are various gear calculators on the net...just google 700R4 speedometer gear calcs. You will need to know your tire size and rear end ratio. For the fuel gauge.....my guess is the float is in the sender is bad....just pull it out of the tank and check it..... Tim
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
09-26-2011, 08:17 AM | #7 |
Welcome to the site. I drive mine daily too.
I think you did good with the $4,500 price tag. I've had 3 over the past few years and that sounds good. I've seen Burbs in a LOT worse condition advertised for more. My speedo also reads high, but it is because of the 20" rims. I have the big mirrors on mine and I was thinking they came from LMC. So... you may want to dig a little deeper on that one. They may be from a newer truck. Of course, from a show perspective... I hate these big mirrors. But from a camper pulling perspective, you couldn't get away with the small ones. I can barely see around my camper with the big ones.
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
09-26-2011, 10:52 AM | #8 |
Wow thanks everyone. I quess I will be putting a sending unit in. And I will check those speedo gears. I will need the big mirrors since I am planning on towing a small trailer.
09-26-2011, 11:21 AM | #9 |
Here is a speedo calculator:
http://700r4.com/speedoCalc/speedocalc.shtml
09-26-2011, 11:27 AM | #10 |
Thanks! I need to find out what gears I have in the rear now. Is there a way without pulling it apart?
09-26-2011, 12:11 PM | #11 |
and from Ohio. That is one Burb
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-26-2011, 12:46 PM | #12 | |
Restoration Virgin!
Jack the rear of the burb up so that both wheels are off the ground. mark the driveshaft, then turn the wheel/tire 2 rotations and count how many times the mark on the driveshaft goes around....3 and little bit is probably 3.08's, 3 and 3/4 is probably 3.73....etc Hope that helps a little bit
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
09-26-2011, 12:51 PM | #13 |
I will give that a shot thanks.
09-26-2011, 12:55 PM | #14 |
Restoration Virgin!
if by chance both wheels spin in the same direction, you may just have a posi rearend too (although someone would of either put a posi carrier in or switched out the rear at some point...it would of been on te SPID..I think)
09-26-2011, 01:03 PM | #15 |
I have a picture of it at the beginning of this post but it doesn't say anything about a rear end. I had the pinion seal redone and don't really want to pull it apart again to find out. I will try that marking the drive shaft and see how many times it turns first and see how that goes.
09-26-2011, 01:05 PM | #16 |
If it doesn't say anything on the SPID would that mean something as a stock rearend with 3.73 gears or something? Just a thought.
09-28-2011, 01:44 PM | #17 |
its all about the +6 inches
having a hard time reading the SPID, is there an engine or tranny option listed? Any sign of a clutch pedal ever being in there?
09-28-2011, 04:12 PM | #18 |
No it doesn't say anything about engine or tranny. In the engine compartment the side sticker on the wheel tub said it came with a 307 )ithas big letters above it saying "AO" if that means anything) and I believe it came with an automatic probably a th300 if I had to guess. It definately doesn't have posi.
09-28-2011, 04:47 PM | #19 |
if there is no listing for an optional trans, then it was probably a 3 speed on the column.
The CE series trucks (2 wheel drive V8) had a 307 and 3 speed as standard equipment. If this is the case, then a 3.73 rear would have been base equipment for that combo. (Asuming the rear has not been swapped) |
09-28-2011, 06:02 PM | #20 |
Thanks for the info. It's not posi I have found that out and I believe it's stock. Now is there a way to get the 3 speedness out from the shift column to a 4 speed? they swapped in a 700r4 and I am wondering if there is a conversion kit for the steering column. I can't a new column right now.
09-29-2011, 10:25 AM | #21 | |
09-29-2011, 11:32 AM | #22 |
Hey 70sarver, this is how the truck came to me. I don't know what they came out of and I don't have any of the other bench seats. I am actually trying to find the bench seats instead or at least the first 2 rows. This originally came with three rows of seats from what the SPID said. I am not sure what you are asking. Do you want pictures of the two seats I have? I don't have a second or thrid row I only have the two seats that are in there now.
09-29-2011, 04:06 PM | #23 |
Welcome to the board!!
Good looking Burb! As to your question on the steering column. You can pickup a 4 speed shift indicator lens from LMC or GMC Paul's. |
09-29-2011, 04:49 PM | #24 | |
09-29-2011, 06:47 PM | #25 |
I have 2004 Silverado 40-20-40 seats in the front and 2000+ suburban 3rd row seats in the back. The back seats fold and flip forward leaving the rear open like a pickup bed. Both sets have integrated shoulder belts....
