Rear Tail Pan Replacement
Anybody here ever see a write up for this project? Replacing the rear tail pan crossmember on the Suburban?
I need to do mine this winter and was looking for others that have done it. I seen one write up a year or two ago but I can't remember where I saw it.
1999 Bass Tracker Pro Team 175 - 40 HP Merc 1989 GMC Suburban V-1500/5.7 L TBI/700r4/NP241C/GM 10 Bolts |
Re: Rear Tail Pan Replacement
I have just started this project myself and just realized that it looks like the body may have to be jacked??? hope not.
If you notch out a quarter panel under one of the tail lights you can get it in there without lifting the body off the frame. I have this done, let me get the pics and post them.
This kicked my butt, but I am very happy with the results, truck is a lot more solid now. This product fit perfectly, had all necessary threaded holes, even had holes for the body wiring harness clips to pop into.
Took a lot of cutting and grinding, but I am over the hump, and can pic away at the small finish work as I please. I sprayed a lot of the Rustoleum Rust Reformer all over everywhere, even the back side of the bumper. Took me about 4 or 5 hours of actual replacement work. Doing all the prep work before hand, like getting fasteners loosened and getting the body mount bolts replaced before hand made a huge difference. You can see in the comparison pics of the old and new parts that 75 percent of the original support channel is completely missing. Enjoy the pics. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() image hosting
Does any body know if they make panels to replace the rust where the ends of this part go ( inside of the quarter panel mine are rusted also). Great pictures by the way they showed me alot.
Thanks Mike |
![]() Join Date: Feb 2014
Great pics. Helps me see what needs to get pulled and what doesn't. Need to do this on my 71. Unfortunately it does not appear that anyone makes a repop for 67-72 subbies. Thanks for posting!
1971 K20 Suburban 2012 LS1500 4WD Suburban 2003 Honda Accord LX V6 (don't tell anyone) MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915 |
#7 | |
