Old 10-04-2011, 05:09 PM   #1
Wscott9689
Wscott9689's Avatar
LS swap manifolds/headers
been doing a little research on manifolds or headers that are not so expensive. im planning on either a 5.3 or 6.0 for my bagged 68 2wd. also which mounts? can you use the truck manifolds if you modify stock towers or use the ECE or POL mounts? any alternative headers that will fit with little or no modifications? long tubes will be ok as long as they will not be below the frame rails. thanks for the help!!
Wscott9689 is offline   Reply With Quote
Old 10-04-2011, 05:24 PM   #2
RocketKing
RocketKing's Avatar
Re: LS swap manifolds/headers
TBSS (TrailBlazer SuperSport) manifolds will fit with nearly any motor mount. Headers are more tricky, Doug Thorley headers are made specifically for our trucks with an LS swap but several folks on here have been able to use different headers than DT's but there are only a few alternatives. There are a couple great threads in here somewhere about this.
Rex
RocketKing is offline   Reply With Quote
Old 10-04-2011, 06:02 PM   #3
Wscott9689
Wscott9689's Avatar
and ill be using a 4l80e also.
Old 10-04-2011, 09:53 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
TBSS manifolds here. For the 80e you need to trim about 3/4" off the drivers side trans "wing".
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-05-2011, 09:56 AM   #5
Shon
I have the big tube LSx Doug Thorley Headers in stock ready to roll out! These will fit just about any motor mount set up that is out there.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-05-2011, 04:40 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I also run TBSS manifolds, and had to trim the ear the same as USM.
The DT's are the only header I know that fits, although I'm not sure how low down they hang.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-05-2011, 04:45 PM   #7
Shon
Not below frame
